Cyl Head info needed !!!
Small Block Mopar Engine
  1. 1Badcolt
    1Badcolt Well-Known Member
    856
    246
    Mar 15, 2013
    Georgia
    Local Time:
    12:40 AM
    Ok so just tonight I finally pulled valve covers to see what cyl heads my 340 has on it and I found the following casting numbers # 3418915
    I also saw 360 on other end of each cyl head so I assume after looking online I have
    1971 360 heads .
    do these particular heads have performance potential and if so how much with serious porting etc
    thanks Chris .
  2. rumblefish360
    rumblefish360 so close yet so far away
    33,469
    5512
    Jun 21, 2005
    New York, on a Island
    Local Time:
    12:40 AM
    Most heads have that “360” cast into it but that doesn’t mean there “360” heads.
    WHat valve sizes?
  3. 1Badcolt
    856
    246
    Mar 15, 2013
    Georgia
    Local Time:
    12:40 AM
    Ok not sure just looked tonight
  4. perfacar
    perfacar Well-Known Member
    1,003
    192
    Mar 1, 2006
    renton,wa
    Local Time:
    9:40 PM
    if you have a 1971 340, it will have 2.02 int valves
    • Agree Agree x 2
    • Like Like x 1
    • 1Badcolt
      856
      246
      Mar 15, 2013
      Georgia
      Local Time:
      12:40 AM
      I guess I want know valve size until I pull the heads and measure them
      Im fixing to sale the 340 minus intake and heads and exh manifolds so I will get info asap.
    • rumblefish360
      33,469
      5512
      Jun 21, 2005
      Local Time:
      12:40 AM
      And make sure there the OE 2.02 valves!
    • 1Badcolt
      856
      246
      Mar 15, 2013
      Georgia
      Local Time:
      12:40 AM
      I do have a 70
      340 I ran the numbers last week.
    • rumblefish360
      33,469
      5512
      Jun 21, 2005
      Local Time:
      12:40 AM
      Which means what for the heads in question?
      I’m missing wht your statement means.
    • 1Badcolt
      856
      246
      Mar 15, 2013
      Georgia
      Local Time:
      12:40 AM
      This is my casting number for the block
      Im assuming with numbers I listed I have a set of 71
      360 heads on my engine ?
    • rumblefish360
      33,469
      5512
      Jun 21, 2005
      Local Time:
      12:40 AM
      Assume, key word and mistake.
      BRB, looking into a book....
      • Thanks! Thanks! x 1
      • 1Badcolt
        856
        246
        Mar 15, 2013
        Georgia
        Local Time:
        12:40 AM
        My 340 is a 1970 model according to casting # on the block !
      • 1Badcolt
        856
        246
        Mar 15, 2013
        Georgia
        Local Time:
        12:40 AM
        Going to unload the 340 but keeping cyl heads
        Intake
        Exh manifolds .
      • krazykuda
        krazykuda FABO Gold Member FABO Gold Member
        46,014
        11134
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        11:40 PM
        They started using the 915 heads on the 340 in mid year 1970...
      • rumblefish360
        33,469
        5512
        Jun 21, 2005
        Local Time:
        12:40 AM
        Easier than typing
        • Like Like x 1
        • Agree Agree x 1
        • 1Badcolt
          856
          246
          Mar 15, 2013
          Georgia
          Local Time:
          12:40 AM
          Ok thank you Sir
          They could be original to motor then ###
          I was told and again undocumented
          That entire driveline came from a 70 Duster .
          • Like Like x 1
          • 1Badcolt
            856
            246
            Mar 15, 2013
            Georgia
            Local Time:
            12:40 AM
          • 1Badcolt
            856
            246
            Mar 15, 2013
            Georgia
            Local Time:
            12:40 AM
            Ten 4
          • brian6pac
            brian6pac Well-Known Member
            3,171
            1693
            Nov 15, 2016
            N.E.Ohio
            Local Time:
            12:40 AM
            look at the vin # on the block and the date code It might be out of a 71 car, also what is the date on the heads
            • Agree Agree x 1
            • furrystump
              furrystump Well-Known Member
              594
              327
              Nov 13, 2004
              Local Time:
              5:40 AM
              Without moving the pushrod pinch you can get about 280 cfm out of an X head. A touch less with the other castings. Unless you are tied to that casting there are more economical choices out there.
            • 1Badcolt
              856
              246
              Mar 15, 2013
              Georgia
              Local Time:
              12:40 AM
              I will get info tonight
              Maybe the heads are original ???
              Hopefully they are 2.02 that would be nice
              • Agree Agree x 1
              • 1Badcolt
                856
                246
                Mar 15, 2013
                Georgia
                Local Time:
                12:40 AM
                Yes sir thank you !!
                I have some decent alum heads to use but was just considering keeping these since they are getting kinda hard to find .
              • furrystump
                594
                327
                Nov 13, 2004
                Local Time:
                5:40 AM
                Unless you are forced to run them by class rules or just really like the idea of running a stock casting it will never be worth putting the $’s into them to get to that level. I view the money I spent on porting my x heads as money very well spent. That being said I wouldn’t even think about an X head if I wasn’t forced to run it. Think of what you could do with $2800-$3000 and a better casting or clean sheet of paper?
              • toolmanmike
                toolmanmike FABO Staff Staff Member FABO Gold Member
                35,218
                17199
                Jan 18, 2006
                Iowa
                Local Time:
                11:40 PM
                #3418915 is a 71-72 340-360 head open chamber with 1.88/1.60 valves. Cast mark "J".
              • 1Badcolt
                856
                246
                Mar 15, 2013
                Georgia
                Local Time:
                12:40 AM
                Yes sir good point !!
                The only limitations imposed on cyl heads is stock valve angle and no off set rockers allowed .
              • brian6pac
                3,171
                1693
                Nov 15, 2016
                N.E.Ohio
                Local Time:
                12:40 AM
                Not really, 68 69 were X heads 894 castings, 70 - 72 J heads 915, 70 & 71 340 had 915 2.02 1.60, 71-up 360 had 915 1.88 1.60, 72 340 had 1.88 1.60, 73 340 587 heads. I have seen chats that say different but over the years I have collected and sold many sets of heads off of 340's and this is what I have seen.
                • Like Like x 2
