mopowers
I recently bought a second hand set of Trick Flow 190 heads. One chamber has been repaired because of a dropped valve I believe (or something else). It appears that the shop that repaired it replaced the intake seat.
However, I noticed the new seat has a larger ID which leaves a slight ridge around the base of the seat (Green arrows). It also looks shorter and the factory TF seat leaving ridge on top of the valve. Maybe because it's missing a top cut? Are these a big deal?
Also, The new seat looks to only have a single seat cut, while the other factory Trickflow seats have what appears to be 3-4 angle cut (can't really tell). It looks like Summit sells replacement seats for these heads.
Should I go ahead and pick one up and have a shop install it and cut the seat to match the factory seats in the other chambers? I already plan on taking the heads to the machine shop to have the deck surface checked and skim cut if needed. I originally planned to lap the valves and reassemble myself, but I'm wondering if it's worth having this seat replaced/re-repaired, or springing for a complete valve job on both sets. Thoughts?
Out of curiosity, I ran some lapping compound on the valve/seat and it looks like it'd seal as-is. It just doesn't match the others. The install height for the valve spring is dead nuts on the 1.950" it should be though.
Other chamber with factory TF valve job:
