Got my 360 assembled with a few pistons to check piston to deck clearence, i'm just about zero decked, about .0011 in the hole using stock crank, scat i beam rods and kb 107's, clevite bearings and speed pro file to fit rings. I have two sets of open chamber stock heads but kind of want to go with a closed chamber head, trying to work on a budget here, my question is what would be a good head choice to achieve a good streetable compression ratio and quench area without having to worry about detonation. just looking for some input from the pro's as this is my first engine build. all input would be appreciated.
