dakota 5.9 starter swap to 72 duster
Electrical and Ignition
  1. 440randy
    440randy Active Member
    31
    3
    Jun 18, 2015
    Canada
    Local Time:
    5:41 PM
    Dont like the size and noise of the stock starters for old school 360s .So going to buy new dakota 5.9L starter from rock auto.What is the best dakota year starter to use.And your experiences with this swap to 1972 duster with old school 360.I am also going to use dakota 5.9L exsaust manifolds as any high flow 340 or 360 original manifolds used cost way to much for the same results when not staying all stock.
  2. pntastar69
    pntastar69 Well-Known Member
    1,558
    209
    Dec 28, 2006
    Gilbertsville, PA
    Local Time:
    10:41 PM
    88 - 92 rings a bell. Wait for others to chime in.
  3. shanker
    shanker Well-Known Member
    146
    56
    May 31, 2006
    Portland, TX
    Local Time:
    7:41 PM
    The one in my (wife's) Duster is out of a 97 Dakota.
    Part Number
    56027702AC
  4. Professor Fate
    Professor Fate Push the button, Max...
    2,469
    3347
    Jan 13, 2020
    Wisconsin
    Local Time:
    7:41 PM
    I used a '96.
    But, a heads up: Some blocks need a bit of clearancing to fit the later starter- there's a lug on the block (used for manufacturing purposes, doesn't mean a thing functionally) right behind where the starter mounts that you may need to hit with a grinder to get the mini starters to seat properly. Test fit it and it'll be obvious.
    Personally, I kinda like the "Chrysler Whine" of the old starters- part of the Mopar character... but there's just no denying the added torque of the Densos.
    As far as the Magnum manifolds go, just be aware that there could be issues if you've got power steering.
  5. dano
    dano Evil Handy Man
    4,073
    1913
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    5:41 PM
    Dakota wasn't the only option, mine came from a Van in a junk yard. Works great. Look for the harness to the starter too.
    Are you sure the Dakota manifolds will work? I know folks have tried the short headers from a Dakota and they didn't work.
  6. shanker
    146
    56
    May 31, 2006
    Portland, TX
    Local Time:
    7:41 PM
    This is good info, because if you grab the entire harness (cable's that go from the Starter to the Battery & to the starter relay) it'll have a nice molded connection on the starter side that will address the clearance issue that people have trying to mount conventional lug type connections on the top of the starter.
  7. Scamp Rhonda
    Scamp Rhonda Well-Known Member
    782
    740
    Jan 18, 2017
    Blaine MN
    Local Time:
    7:41 PM
    This is what I got. Makes my 318 want to jump out of the engine compartment.
    Steve
    https://www.amazon.com/dp/B00KGID3MI/?tag=fabo03-20
  8. Demonx2
    Demonx2 FABO Gold Member FABO Gold Member
    651
    1128
    Dec 10, 2019
    Michigan
    Local Time:
    8:41 PM
