sport74
Has anyone seen or swapped a rear disc set up off a Dakota 8.25 to a 8.75? I was thinking this might be a cost effective conversion and wanted to see if it had been done before
It should bolt right onto the 8-3/4.
Don't forget gotta have green bearings!!!
Dodgedifferent2 do you have to have the green bearings? If so how can you tell if you have them already? My 8.75 came out of a 66 charger if that helps. And how much are your brackets?
the emergency brake setup on mopars is stupidity in a box.
the real key is mustang rotors and use ford mustang calipers, then the emergency brake is simplified by 1000%
http://www.forabodiesonly.com/mopar/showthread.php?t=128394
