1. replicaracer43
    replicaracer43 Grumpy Old Man
    5,156
    4775
    Oct 10, 2008
    Local Time:
    12:56 AM
    There is a LOT better talent in a bunch of members right on this site, and you can find ANY answer to any question with a simple search here.
    • Agree Agree x 3
    • Thanks! Thanks! x 1
    • Princess Valiant
      Princess Valiant Duster specialist
      24,880
      19343
      Dec 14, 2011
      Colorado
      Local Time:
      11:56 PM
      The side by side comparison was really nice because I had often wondered what the difference is and seeing the side by side really puts the visual in my brain
      • Like Like x 4
      • Agree Agree x 2
      • replicaracer43
        5,156
        4775
        Oct 10, 2008
        Local Time:
        12:56 AM
        I did my first LA to magnum swap in about 99 or so, and I have often said even on this sight, a running junkyard magnum is the budget guys best option.
        • Like Like x 2
        • Agree Agree x 2
        • Keystone
          Keystone Well-Known Member
          232
          331
          Dec 16, 2016
          Central PA
          Local Time:
          1:56 AM
          I haven't watched the video, but it seems to me if your replacing a worn out 318 or upgrading from a slant, using a cheap and readily available Magnum makes a lot of sense. Not everyone wants to build a race motor. Refurbished to stock specs and you have better flowing heads, more compression, roller lifters... And for saving money you can even drill the heads and reuse an old LA intake manifold.
          That's what I'm in the middle of anyway. I'll let you know how it goes when it's all done, but so far I have no regrets on going with a 5.2 instead of a 318 LA.
          • Like Like x 5
          • jos51700
            jos51700 Green Bearing thread connoisseur
            6,064
            2856
            May 24, 2009
            Bel-Ray
            Local Time:
            12:56 AM
            The magnum has much potential beyond and above the LA, namely roller cam, 1.6 ratio rockers, and the heads, although crack prone, are superior to any LA casting. Personally, I wonder if the cracking issue wasn't less of a thing than the internet made it out to be, namely because EQ or somebody would still be cranking those out if there was money to made there. I almost wonder if, for a many magnums are still out there, if the ones with terminal cracking have been filtered out. Disclaimer: I've not read up on why EQ got out of the game.
            If I'm going V8, I'm going aluminum heads. If performance is what I'm after, do it right. If not, a bone stock slant 6 is fine.
            All that said, I've vowed never to run another LA, but if I swap again, it'll probably just be to a gen III hemi, namely because they're still in production so the parts will be around longer than the magnums, but also if it's a power game, they win.
            • Agree Agree x 2
            • Like Like x 1
            • Disagree Disagree x 1
            • MOPAROFFICIAL
              MOPAROFFICIAL FABO Gold Member FABO Gold Member
              9,992
              9320
              Jun 1, 2016
              Oceanside ca.
              Local Time:
              10:56 PM
              It's no big deal, but its funny....to read people accept the magnum and over look the springs while they would never do that with the older LA motors. Nope... its ..."i would be changing the springs right away and sliding in that 256 or 262 cam and lead footing it off into the sunset..."
              So I wanna know if these people are really tossing in a magum engine and just driving it with the stock cam and springs of which 'the stock springs are done and floating after 4500 rpm' while the stock cam is still there till about maybe 5200 rpm. 1st thing I did was change the springs and put some heads on. It pulls into 5500 range now.
              My advice to all you guys buying one of these engines put it on the stand , change the oil pump , timing chain, remove heads and do the spring work whether changing the cam or not. It will turn more rpms qith more spring. The 986 comp double 1.437 is a good one to about .500 lift/55-6000rpm, after that get a better spring with more open. Those are only about 290's lbs open but have 130 seat lbs.
              I would not put 500 into any stock casting magum head...so be sure they are good to begin with.. if not, get after market sm,eq,rhs,etc
              • Like Like x 3
              • JunkyJimmy
                JunkyJimmy FABO Gold Member FABO Gold Member
                34
                31
                Jun 2, 2017
                Corn Field
                Local Time:
                12:56 AM
                Hughes has a spring,retainer,locks package that is drop in,good to 540 lift for $200.00
                • Like Like x 2
                • MoparLeo
                  MoparLeo NRA BENEFACTOR LEVEL LIFE MEMBER FABO Gold Member
                  1,003
                  720
                  Feb 10, 2016
                  Moreno Valley, Cal. So. Cal.
                  Local Time:
                  10:56 PM
                  The Magnum was a truck only application. Low rpm was always in the design. Springs are needed for any serious rpm's regardless of the base engine.
                  Smoother castings and improved combustion chamber and port shape of the EQ heads = more flow...
                  Heads are the key to power on any engine.
                  • Agree Agree x 1
                  • mopardude318
                    mopardude318 Well-Known Member
                    10,247
                    1915
                    Jan 7, 2005
                    Gilroy, Ca
                    Local Time:
                    10:56 PM
                    I like the LA roller cam block if you were to start a new build. Uhhmmm hhhmmmm
                    • Agree Agree x 2
                    • MOPAROFFICIAL
                      9,992
                      9320
                      Jun 1, 2016
                      Oceanside ca.
                      Local Time:
                      10:56 PM
                      Now just cut the guides down to clear over .470 lift...
                      • ou812
                        ou812 Well-Known Member
                        1,495
                        431
                        Jan 15, 2005
                        SoCal
                        Local Time:
                        10:56 PM
                        We also have one, not a conical though but fits the OEM rockers, allows .550 lift, 125lbs. installed, and 260lbs. open at .550 lift. It runs 230.00 for the springs and retainers, no machine work and you can use the oem locks.
                        Springs not a big deal...the magnum is a great platform!
                        • Like Like x 5
                        • Thanks! Thanks! x 4
                        • Agree Agree x 1
                        • barbee6043
                          barbee6043 barbee 6043 FABO Gold Member
                          15,501
                          8558
                          Jul 20, 2008
                          Shepherd, Texas ( SE Tx)
                          Local Time:
                          12:56 AM
                          Ever time I rev over 4500 rpm, my wife, riding shotgun, gets nervous and wets her pants! So we just poke along.:BangHead::poke:
                          • Like Like x 1
                          • Agree Agree x 1
                          • jos51700
                            6,064
                            2856
                            May 24, 2009
                            Bel-Ray
                            Local Time:
                            12:56 AM
                            I'm kinda dumb. Other than the oiling passage, is there any other difference?
                          • Bobzilla
                            Bobzilla Well-Known Member
                            1,135
                            883
                            Aug 10, 2017
                            Southeast Michigan
                            Local Time:
                            1:56 AM
                            Now this is damn good info.
                            Thanks for posting this. I had no idea you guys offered a spring kit.
                          • sireland67
                            sireland67 FABO Gold Member FABO Gold Member
                            9,773
                            4189
                            Oct 27, 2010
                            WV
                            Local Time:
                            1:56 AM
                          • Bobzilla
                            1,135
                            883
                            Aug 10, 2017
                            Southeast Michigan
                            Local Time:
                            1:56 AM
                            LA hydraulic roller cam block has the same oiling as non-roller LA block.
                            First year or two Magnum blocks actually had LA oiling holes drilled.
                            Remaining Magnum blocks do not have LA oiling holes drilled, but these can be drilled if really desired. LA heads can be used by running the stainless steel, roller tip, shaft mounted LA rocker arms like those by Comp Cams and copied by PRW and Speedmaster, that allow oiling through hollow pushrod.
                            Any Magnum block can be built to replace an LA engine as long as the proper parts are used. If an LA timing cover is used on the front, you can use LA oil pans, oil pump and pickup, water pumps, and v-belt pulley setup. Just make sure a stock 360 Magnum rotating assembly always gets a 360 Magnum harmonic balancer and weighted flex plate so a common neutral converter can be used.
                            If a new LA rotating assembly with forged crankshaft and internal balance is used, you can obviously run the neutral flex plate, harmonic balancer, and converter.
                            If a cast LA 360 rotating assembly is used that is still external balanced, use those LA 360 parts as you would on a full LA 360 build.
                          • Bobzilla
                            1,135
                            883
                            Aug 10, 2017
                            Southeast Michigan
                            Local Time:
                            1:56 AM
                            Almost forgot, supposedly a 5.2/318 Magnum rear main cap is externally machined the same as a 5.9/360 Magnum, so both of them accept LA oil pans.
                            The Magnums used much better one-piece oil pan gaskets that can be used with a Magnum timing cover and accessory drive serpentine belt setup, but the Magnum gasket also works well on the LA timing cover with a little extra silicone in the gaps at the front. I have a Milodon LA 360 oil pan on an LA hydraulic roller block. The front oil pan seal holes in the Milodon pan were so far off I could not use the LA gasket setup at all, but the Magnum gasket sealed up nicely.
                          • 318willrun
                            318willrun Utube channel 318willrun
                            18,457
                            21498
                            Sep 13, 2013
                            I'm here
                            Local Time:
                            12:56 AM
                            I bought 'em, dropped 'em on stock mag heads, and threw in a regrind cam I'm about .530 lift on exhaust, just got it going and no issues so far, had it to 6k easily.
                            • Like Like x 4
                            • Thanks! Thanks! x 2
                            • MOPAROFFICIAL
                              9,992
                              9320
                              Jun 1, 2016
                              Oceanside ca.
                              Local Time:
                              10:56 PM
                              Another great option.
                              What the highest lift you would run without cutting the guides down...470 ish?
                            • Mopar Sam
                              Mopar Sam Well Fed Member
                              1,560
                              2339
                              Jul 18, 2008
                              Indiana
                              Local Time:
                              1:56 AM
                              One of my sons uses Lunati #73949 springs on his Magnum r/t heads, with Hughes retainers. He runs .575 lift in his daily driven D100.
                              • Like Like x 1
                              • MOPAROFFICIAL
                                9,992
                                9320
                                Jun 1, 2016
                                Oceanside ca.
                                Local Time:
                                10:56 PM
                                R/T heads are a different story. Nice heads
                                The installed height is greater with those and 2.02 intake valves.
                              • Mopar Sam
                                1,560
                                2339
                                Jul 18, 2008
                                Indiana
                                Local Time:
                                1:56 AM
                                1.65 installed height on his r/ts, with stock length 2.02 /1.62 valves. That spring # I posted will work with stock mag heads. Original application is for pontiacs, which also have a short installed height.
                                I agree, the r/t heads are good. They took the mess out of the port roof. They also are made such that you can tube the pushrod holes.
                                • Like Like x 2
                                • greymouser7
                                  greymouser7 Vagrant Vagabond “Veni Vidi Vici”
                                  3,537
                                  2812
                                  Apr 17, 2010
                                  78002 down the road from Atascosa, Texas
                                  Local Time:
                                  12:56 AM
                                  Where is that please sir? I cannot imagine anything being that cheap at Hughes!
                                  • Agree Agree x 1
                                  • JunkyJimmy
                                    34
                                    31
                                    Jun 2, 2017
                                    Corn Field
                                    Local Time:
                                    12:56 AM
                                    Got me, I just looked $219 now and probably $40 freight!!!!
                                  • 66fs
                                    66fs FABO Gold Member FABO Gold Member
                                    6,320
                                    2829
                                    Sep 9, 2009
                                    Greenwood, South Carolina
                                    Local Time:
                                    1:56 AM
                                    What do you want to learn?
                                    • Like Like x 1
