Damn oil leak, Rear main??
Small Block Mopar Engine
  1. 340Duster247
    340Duster247 Well-Known Member
    832
    272
    Dec 5, 2012
    Calgary
    Local Time:
    6:36 PM
    Hey guys, I've had this little small block in and out many times with various combos and rebuilds and along the way I've never had an oil leak that's acted like this one so maybe you could help me out.
    This is bar far the worst oil leak I've had, shut off the engine and got the dreaded drops coming from the back upper of the pan. "f**k I guess the engine had to come out" but before I pulled the engine I figured I would investigate. Seeing how this new engine/combo just went in at the start of summer I'm not really to motivated to yank it.
    Got under the car and cleaned up everything removing any oil mess since this leak happens to get onto the flex plate and spatter everywhere.
    With it all clean, I start the car and wait and look. Nothing. Dry. Zero leaks. Let the car idle and get up to temp. After 30 mins of run time I rev the engine a couple times. Under the car still nothing. Dry.
    I shut the engine down, get under the car and it instantly starts coming out at a pretty good pace.
    Hmmmm, rear main seal???
    Anyone had a similar leak.
    I think I have an idea what's going on , but want to get the wisdom from you guys first. Lol
    Added a photo of the leak and new combo for ya guys too.
    • Like Like x 1
    • cawcislo
      cawcislo Well-Known Member
      319
      204
      Aug 7, 2018
      Ontario, Canada
      Local Time:
      8:36 PM
      Would pulling the trans help verify the leak and could you do the repair without pulling the whole motor out? If it is the rear main - Do you have enough clearance to pull the oil pan if needed by lifting the engine a couple inches?
      PS the turbo looks killer.
      • Thanks! Thanks! x 1
      • 340Duster247
        832
        272
        Dec 5, 2012
        Calgary
        Local Time:
        6:36 PM
        Well what's great is no headers. So I have more room then normal. I was thinking about pulling the trans back (or out completely to take a look) I've yanked that trans more then couple times ... Ughhh bit of a night mare with just a couple floor jacks, but might be an option.
      • abdywgn
        abdywgn dismantler
        1,546
        807
        Jul 30, 2006
        Darien, Illinois
        Local Time:
        7:36 PM
        cam plug? mine would leave the puddle on shut down...who knows how much was sprayed while driving. the later Magnum style would be the one to use instead of the earlier welch(?) plug.
        • Agree Agree x 1
        • MarPar
          MarPar If it weighs, it pays FABO Gold Member
          939
          1661
          Aug 15, 2010
          Madigadistan
          Local Time:
          7:36 PM
          • Agree Agree x 4
          • DFX 340 Duster
            DFX 340 Duster FABO Gold Member FABO Gold Member
            1,752
            577
            May 14, 2009
            Orange County CA
            Local Time:
            5:36 PM
            Just pull the engine and tranny and replace the rear main seal. Add another turbo while you have the engine out of the car.
          • Mike69cuda
            Mike69cuda 64 is the new 17 FABO Gold Member
            1,876
            1404
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            7:36 PM
            I replaced my rear main without removing the engine or trans. Most of the work is dropping the steering. After you get the pan off it is easy.
            • Like Like x 2
            • Agree Agree x 1
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              19,435
              7268
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              7:36 PM
              When you get the seal out; inspect it very carefully.
              I had my block line-honed, and within a couple of hundred miles I had a leak. I said to myself "hunh" and simply replaced it. A couple more hundred and the leak shows up again. Now I'm pissed cuz I know I did everything I could to make sure it wouldn't leak.
              So I went and dug up the first leaker, and lo and behold, the reason for the leak was right there staring me in the face. The lower half was heavily worn, and the upper had no visible wear.
              So I deduced that during the line-hone, somebody got a little carried away..... and the main-cap was forcing the upper half up and off the crank.
              So I pulled the second seal, and it looked the same.
              So I went and bought a rope-seal off a 383, and fit it into there, badaBoom.
              So I took the seals to the machine-shop that did the work. The shop that just decked this block, and fresh-honed the cylinders.
              You won't believe what the manager said.
              He said that if I would supply another block, they would give it a line-hone no charge. but
              I would have to pay for the decking and the boring and the honing.
              You're kidding I said, among other words.
              Needless to say, the rope seal has been seeping ever since, but not enough for me to do anything about.
              And I never recommend that shop.I don't diss them, I just don't recommend them.
              • Like Like x 1
              • 66jim
                66jim Well-Known Member
                536
                498
                Dec 11, 2007
                NE PA ie pennsyltucky
                Local Time:
                8:36 PM
                Oil funnels down to the low spot where you see it and may appear as a real main seal leak. It can also be the distributor O ring or gasket, the oil sending unit, the China rail, the oil filter gasket, valve cover gaskets and even the fuel pump and timing cover towards the front. When driven air pushes the leak back and it all drips from
                the low spot. Take it from someone who has gotten fooled.
                • Like Like x 2
                • Agree Agree x 2
                • 340Duster247
                  832
                  272
                  Dec 5, 2012
                  Calgary
                  Local Time:
                  6:36 PM
                  Well boys I got motivated and pulled the trans so I could see behind and maybe get a better idea..well there too much spatter to tell. It looks like some of the plugs could be leaking but it's too hard to tell. I also can't tell if it's where the oil pan meets below the crank, or the main seal it's self.
                  F**k I hate leaks. Ughh.
                  I didn't mine pulling the tranny as I'll be installing a cope valve body and trans brake this winter.
                  • Like Like x 1
                  • Divenut
                    Divenut Well-Known Member
                    3,150
                    1480
                    Sep 22, 2011
                    Naperville Illinois
                    Local Time:
                    7:36 PM
                    Is that the CRT RMVB with the low band apply?
                  • 340Duster247
                    832
                    272
                    Dec 5, 2012
                    Calgary
                    Local Time:
                    6:36 PM
                    It will be yes.
                    • Like Like x 1
                    • Divenut
                      3,150
                      1480
                      Sep 22, 2011
                      Naperville Illinois
                      Local Time:
                      7:36 PM
                      Nice. Seens like a very nice piece. I hope to hope to replace my current Cheetah RMVB w/o low band apply unit with the CRT unit.
                      Be well,
                      Pat
                    • famous bob
                      famous bob mopar misfit
                      17,862
                      7310
                      Aug 14, 2011
                      okla
                      Local Time:
                      7:36 PM
                      • Agree Agree x 1
                      • George Jets
                        George Jets 1967 Dart 2 Door FABO Gold Member
                        3,396
                        4947
                        Jan 18, 2019
                        Farmington MN
                        Local Time:
                        7:36 PM
                        I have lately been wondeing about those rear main seals.
                        There is the earlier rope seal and the angled knurling on the crank seal area. I can see how this works with the engine running winding the oil back into the engine with the knurling. With the engine sitting off, can the oil seep back through the knurling?
                        Then on a rebuild or newer lip seal rear main seal. The new lip seal sitting on the knurling, with it running pushes the oil back into the engine.
                        With the engine stopped the new lip seal would be bridging the knurling peaks and allowing oil to run back out throgh the knurling valleys ??
                        So my question is with the lip seal style rear main seal, would it be a good idea to polish down the knurling smooth so the rear main lip seal has a smooth surface for the lip to seal against.
                        Just like the smooth surface seal up on the front harmonic balancer and timing cover.
                        Also wondering if the aftermarket cranks and stroker cranks have eliminated the knurling altogether ???
                        Maybe even the stock reman cranks have the knurling removed as part if their reman process ??
                        Granted you want a good vented crank case and PCV setup to eliminate any positive crank case pressure pushing the oil out.
                        Any thoughts or opinions on this ???
                      • AJ/FormS
                        19,435
                        7268
                        Jan 19, 2014
                        Local Time:
                        7:36 PM
                        To pinpoint the leak just seal the engine, and then pressurize the CC to 3 psi/ not more than 4psi, and then hit it with soapy water.
                        To seal the engine, I flip out the PCV, and plug the hole, same at the breather. Then I pressurize thru the dipstick tube.
                        • Like Like x 2
                        • cawcislo
                          319
                          204
                          Aug 7, 2018
                          Ontario, Canada
                          Local Time:
                          8:36 PM
                          Clean up the rear of the block. With the trans out you could also grab an oil priming tool and have someone spin the oil Pump to get oil pressure, pull the spark plugs and rotate the engine to get oil everywhere to see if you can pinpoint the leak. Or maybe even just fire the engine up for a short bit of time...Try it a couple times as it seems like you said the problem shows up when you shut the car off. You may also want to make sure the car/engine is level (or as level as it normally sits when the problem occurs). Good luck.
                        • 340Duster247
                          832
                          272
                          Dec 5, 2012
                          Calgary
                          Local Time:
                          6:36 PM
                          Good stuff. This crank was used is the last setup before I switched to lower compression pistons and had zero issues with the rear. I guess I won't know till the pan comes off.
                          As far as blow by this engine has very minimal if any at all. It also has two -12 lines to the catch cans to allow it to breath.
                          Might have to look into a good PCV system if this continues.
                        • furrystump
                          furrystump Well-Known Member
                          1,109
                          706
                          Nov 13, 2004
                          Local Time:
                          1:36 AM
                          Something that is SO FAR out there I have to mention it. I don’t think it is your problem. I have seen where the pilot hole on an aftermarket crank was drilled to deep and intersected the rod oil galley in the crank. There was a video, he would run the drill and build oil pressure and you could see the oil slowly start coming out of the pilot hole. Have to file that under “the last thing I would check!”
                          • str12-340
                            str12-340 FABO Gold Member FABO Gold Member
                            1,285
                            698
                            Dec 26, 2012
                            Vashon, WA
                            Local Time:
                            5:36 PM
                            Before you do a lot of work, I'd check that whatever gauge tubing or sending unit you have screwed into the oil pressure tap at the back of the motor (next to the distributor) is not loose. Oil is insidious in that it works its way everywhere once it leaves the motor.
                          • 340Duster247
                            832
                            272
                            Dec 5, 2012
                            Calgary
                            Local Time:
                            6:36 PM
                            Thanks , but I've checked all that. This car uses electric sensors for my Holley software, and all dry up top.
                            • Like Like x 1
                            • teringer
                              teringer ase master hall of fame FABO Gold Member
                              851
                              204
                              Feb 22, 2011
                              kenly nc
                              Local Time:
                              7:36 PM
                              someone makes a bearing kit that pulls oil away from the rear seal on engines with high oil pressure .I had same problem with 360 in my dirt car note only the last main bearing was different it had a groove cut in it
                            • cawcislo
                              319
                              204
                              Aug 7, 2018
                              Ontario, Canada
                              Local Time:
                              8:36 PM
                              Any update? Did you figure it out?
                            • B3422w5
                              B3422w5 Well-Known Member
                              1,323
                              1308
                              Feb 9, 2017
                              Portage michigan
                              Local Time:
                              8:36 PM
                              If it was me i would buy some dye, put it in the engine, run it, then use a UV light.
                              Makes it 50 times easier to spot the leak. You may not have to pull everything out that way. Very easy to do.
                              • Agree Agree x 1
                              • 340Duster247
                                832
                                272
                                Dec 5, 2012
                                Calgary
                                Local Time:
                                6:36 PM
                                Hey guys here's the update. Trans removed, cleaned everything up. Primed engine to get oil pressure and sure enough it's the rear main. Now I have to decide to yank the engine or try it with engine installed. If it wasn't for all the turbo and exhaust piping I'd yank the engine right away....
