Which year is that? for the same year, yes, they should all interchange except for a convertible. '63's are all by themselves, but, 2dr sedan, 2dr HT, and 4dr sedan use the same peak molding. There are two versions though.....a 2 piece and a 1 piece. Not sure why.....maybe early and late '63? In the '64-models, they're all the same between 2dr sedan, 2dr HT, and 4dr sedan. There again, the convertible is different....mainly shorter. I've cut down the long ones to use on a convertible. Those are RH and LH too, as there's a slight bend in them.
