Dash Light Size...
lemonboy69
It's JUST a Slant Six...
Clermont, FL
So I've already tried searching for the answer to this question, but to no avail... :wack:
What bulb number are the dash lights in the '67-9 B'Cuda's? I know, I could crawl under my dash and pull one to check, but I'm sitting here at work and I found some LED replacements on Ebay. Figured I could ask you guys and somebody would probably know!
Thanks in advance! :thumblef:
EDIT: Found this link from the manufacturer... http://www.whitegauges.net/led_results.php?brandID=5 - Looks quite reputable. I think I'm going to go for it! :D
Lmb 69
Instrument cluster light bulbs in my 67 B-Cuda are #158, but I have seen # 194 there also. I think # 194 is brighter. These are both the little all glass bulbs that fit in the black plastic holder that turns into the back of the printed circuit board.
Hope this helps.
Dave C.
