Slant Six Bumblebee
none of my dash lights work. i pulled the switch it looks brand new.
none of the dash lights work but all the other functions of the switch work. when i rotate the switch counter clockwise it turns the dome light on.We are gonna need some more in--for--ma-tion............
How Mopar Dash Lights Work:
Dimmer controlled dash lamps are powered through the headlight switch OFF THE TAIL/PARK circuit. So that fuse must be good and those lamps must work
Then with the light switch in either park or headlights, twist the dimmer control to the left. Wiggle it around it might have a "bad spot or be dirty."
That power from the dimmer control now LEAVES the light switch on a tan wire and goes down to the INST fuse in the fuse panel. That fuse is usually at one end of the fuse panel. From there, all dimmer controlled lighting goes out from that fuse on ORANGE wire
Does ANY dash lamp work? Shift quadrant? Radio lamp?
How about what kind of vehicle are you working on?none of the dash lights work but all the other functions of the switch work. when i rotate the switch counter clockwise it turns the dome light on.
what is the easyest way to remove the gauges
i checked the inst fuse it was not getting any power. Does anyone have a circuet diagram of the switch so i can test it.
There most certainly is---------72I cant download the manual there is not one for the 1972.View attachment 1715702124
