Theres a member on here that makes an adapter to fit two round speakers in the 4x10 location, if your using the original radio which only has two wires than the 4x10 will be fine, if your going to say a retro sound radio that uses seperate channels than the dual front speaker setup would sound best
If you're replacing the speaker to use with the OEM radio, be sure to get one whose impedance is rated at 8 ohms. A 4 ohm speaker, which is the most common today, could damage your radio.
