Dash wiring
AARFJ6
SC
Can anyone tell or show me a picture of how the power gets to the under dash map light and cigarette lighter.
Thanks, the wire going to the fuse box is gone. Putting a new harness in and didn't
know where the power should come from.
So this wire that has been cut goes to the fuse box?
So this wire that has been cut goes to the fuse box?View attachment 1715260445
What I see there does not exactly look factory?? Yellow is often associated with switch side of the courtesy circuit
If you can trace any leg of that point you showed to a connector, showing the shape of the connector and color of the wires then we could likely ID it
Yellow and pink go to the map light then pink to the cigarette lighter.
