Fast340cuda
I just picked up what I believe is a big block DC K frame. Upon measuring the mount offset I’m getting 3/4” on the passenger side and roughly 7/8” on the driver side vs 13/16” and 1 3/16” from Jim Lusks posted dimensions for his modified small block version.
Thinking the passenger side will work as is but may need to cut the driver side mount off and slide it back.
Was hoping someone on here has an original DC k frame that they could measure and confirm what they have for an offset. Also would like to know if the dimensions are close to mine, were you able to mount the motor without much trouble?
Thanks!
Thanks!
