Melling cam is veryh old SBC lobe- it sucks
we used to buy these for cheap cores to regrind
AS said above he needs to get the intake closed early to build cylinder pressure- dynamic compression
he needs to open the exhaust late for maximum expansion
Timing on 250 comp is better
Timing on 256 comp is about Max
(from the diagrams @.006 on the comp website)
problem is all short comp cams have little lift for their duration
Jones 256 cam is actually shorter seat to seat thanthe comp 250 or shortest Voodoo but with .305 lobe lift and lots of area to still make some power.
Problem is cost and deliver ability but now that race season is over that should be easing
I'd buy JOnes but smallest Voodoo or custom Bullet are good second choices
Of course Engle, Crower etc can also grind a short high lift custom
other shelf cams may rev like crazy but leave much torque on the table
