Del does not follow his own advice, AKA Cummins Whale
Mopar General Discussions
  1. A408Cuda
    A408Cuda FABO Gold Member FABO Gold Member
    538
    682
    Mar 5, 2018
    South Dakota
    Local Time:
    9:25 PM
    You did good on that one just the running motor will catch $5k to $7500 around here.
  2. 67Dart273
    67Dart273 Well-Known Member
    39,501
    7146
    Oct 14, 2010
    Idaho
    Local Time:
    7:25 PM
    Well it's home and paid for, my bank has the drive-up open 9--1PM. Funny thing is the (really hot) little gal did not seem to have a way of issuing a bank draft/ cashier's check but she had no problem handing over 5K in green. That is the most money that went through my hands the fastest, I've ever had, in cash.
    • Like Like x 3
    • 75slant6
      75slant6 Well-Known Member
      4,957
      1418
      May 15, 2011
      Russellville, ky
      Local Time:
      9:25 PM
      We’re not gonna be able to take your word on that, we’re gonna need pics for proof. :D
    • RustyRatRod
      RustyRatRod 30 Degrees Outta Whack FABO Gold Member
      51,153
      18193
      Jun 7, 2010
      Georgia
      Local Time:
      10:25 PM
      Congrats, Del. But I must concur, pics of the really hot little gal would be good. Just drive back Monday and tell her that a bunch of pervs on an internet forum want to see her. lol
      • Agree Agree x 1
      • gunbunny
        gunbunny FABO Gold Member FABO Gold Member
        2,435
        1157
        Apr 14, 2009
        Cincinnati, OH
        Local Time:
        10:25 PM
        No vacuum controls, all electrical. Likely a mode/temp door actuator, sold a ton of them over the years.
        Be real careful of the lift pump going bad! You won't even know it went until injector pump craps out on you.
        There was a TSB out there once upon a time that moves the lift pump to the tank like a normal fuel pump. If you have that set up, you should be good.
        Have fun with it. I've kicked myself in the ass several times since last summer. I let a damn nice 07 4X4 4dr w/98K get past me. I should of just ponied up and bought it. I haven't seen one that nice since.
      • 67Dart273
        39,501
        7146
        Oct 14, 2010
        Idaho
        Local Time:
        7:25 PM
        Yeh I found that on the www already I may add a gauge/ warning setup on that
      • 67Dart273
        39,501
        7146
        Oct 14, 2010
        Idaho
        Local Time:
        7:25 PM
        Well it's mud, mud, and more mud, but I got the really nice commercially built rack off (likely sell it) and was gonna remove the 5th wheel mount but I think I'll torch/ plazma the bolts
        This is sposed to be a "local" rig and there doesn't appear to be ANY rust issues. Underside is nice except for a bit 'o dirt and just a film of that. In other words it has not been mired down in some hole
        I just had to.........the fuel warning was dinging, so I illegally (no plates) drove it a couple miles up to the "gas" station and bought 10 gal---my first time ever putting a diesel nozzle in a rig
        • Like Like x 2
        • 67Dart273
          39,501
          7146
          Oct 14, 2010
          Idaho
          Local Time:
          7:25 PM
          Made some minor headway today. Removed the fifth wheel brackets from the bed, which required removing the (very heavy) spare
          AND I may have fixed the heater/ AC. Vacuum line dropped out of the vac pump connection!!! I havent driven it, but started it up, warmed it and moved it, and it seems to work "as expected." AC compressor cycles, so it's low on refrigerant, but not completely out
          Still not sure on the oil leak. It does not seem to have blowby, but it has a phony plastic breather/ vapor separator catch can up front. It had maybe?? 2-3 tablespoons of oil in there, which I drained. You are supposed to drain it 'every so often' What a POS!!!! Chrysler Fiat/ Cummins? YOU COULD NOT AFFORD A REAL CAN WITH A DRAIN PETCOCK??
        • mcodecuda
          mcodecuda Senior Member
          467
          69
          Sep 17, 2007
          Mooresville, NC
          Local Time:
          10:25 PM
          The dealer moved the lift pump to the fuel tank in my 02 and my fuel pressure went down. I ended up removing the pump in the tank and upgrading to a medium price fass pump and mounted to the frame.
        • 67Dart273
          39,501
          7146
          Oct 14, 2010
          Idaho
          Local Time:
          7:25 PM
          ^^I forgot to look this morning and see if it looked like it had been modded. I "have a lot to do" LOL. Have to get the camper/ stuff out of the old truck, and the mud, the mud, THE MUD!!!! (And it's gonna rain..................)
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          10,919
          1586
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          9:25 PM
          I run a Holley blue pump on my 01 diesel dodge. Has 14 lbs fuel pressure all the time. Been on 7 years. Kim
        • Back in Time
          Back in Time Well-Known Member
          4,702
          1242
          Mar 2, 2013
          Sun City West,Arizona
          Local Time:
          7:25 PM
          My 01 24 valve was a much better truck than my 08 6.7. You got a good deal.
          Correction on year of Truck. Been a long time ago.
        • 67Dart273
          39,501
          7146
          Oct 14, 2010
          Idaho
          Local Time:
          7:25 PM
          Got plates and insurance taken care of today, ran out to Post Falls and back, some errands. Really "warming up" to this, the torque is incredible. Assuming no big troubles I'm sure I'll like this. Got the old "White Whale" on the hoist--to pull the winch battery cable and backup camera wiring out, and got the little camper removed. It will be up for sale in a few days
          • Like Like x 1
