delima... distributors
project360
Tucson
so, looks like my proform HEI will not fit with the T-ram....
so in the market for dist.
i really like the pertronics flame thrower II and the mopar performance electronic dist. with rev box..
any do's and dont's here ?
So you're not saying why is doesn't fit so I ask you, Is it that the vacuum advance hasn't the room to turn? If that is the problem which I too had, what I did was grind down some of the manifolds little mountains and everything was serendipity from there. I hope you can see from the photo as after I ground down some of the manifold, it now turns well. The screwdriver you see is the handle for the transmission dip stick and sits far away from the dizzy and the photo makes it look closer.
must be hard getting an over the counter cap and rotor button at your normal parts place for one of those units?
MSD E curve. No box needed. Multi spark, rev control, easy to set curves...
OK, so it does fit just as yours does, however it only has about 3/4 of an inch rotation... so im going to leave it as is and see if i can get it running.from where its sitting, i can only turn it clock wise that 3/4 in the same location you see it here.
[/QUOTE]
