Demon Of A Tire Dilema
demonman
New Member
ohio
I'm Putting New Tires And Wheels On My 71 Demon. I'm Worried About The Fit On The Rear Tires I've Already Ordered. Does Anyone Know If A 255/70/15 Bf Goodrich Ta On A 15x7" Rim With A 4" Bs Will Fit Ok? The Tire Diameter Listed Is 29.1". I'm Worried Most About The Tire Diameter Being Too Large To Fit. Thanks In Advance.
Yes I'm running 255-60x15 on the back of my Demon with no problem with the 15x7 SBS cragars. Fits fine. Your 255-70's are the same width just a little taller tire (2" larger dia.)
Terry
Terry
I'm using MT ET street radials that are 255/60/15's on my '72 Duster that are 28 inches tall without any problems. I have 15x10 inch rims with 4 3/4 inch backspace and they are very close to the fender lip and spring.
Go to Tire Rack www.tirerack.com and check how wide the T/A is. Mine are approximately 11 inches wide and thats as large as will possibly fit in my wheel wells.
Depending on your wheel, a 29 inch tire is not an easy fit in a demon. My duster has 28 inch tires and its rather close to the quarterpanel up front. good luck
I agree...I have L60-14's on the back of my Demon and they are VERY close to the front of the quarter panel -- these are 29" tall tires too. It's tight, but they fit and don't rub...yet.
