Does anyone know where a replacement rivet can be found for the 2 red arrow locations? What about the white plastic insulator at the front of the window represented by the green arrow? Thanks Warren
You have to drill the old ones out and make the holes ever so larger , go to home depot they have short rivets.Measure the rivet before you drill the hole. I couldnt find the white plastic.
Andrew
