A A/MP Well-Known Member Joined Nov 26, 2005 Messages 592 Reaction score 70 Oct 12, 2018 #1 Installing Denso mini alt. Collect parts at this time. Isn't there some type of plug that I will need to connect the Denso to my wiring? Napa part #?
brian6pac Legandary Member Legendary Member Joined Nov 15, 2016 Messages 5,668 Reaction score 4,091 Location N.E.Ohio Oct 12, 2018 #2 isn't that a 1 wire unit? 50 amps right
A A/MP Well-Known Member Joined Nov 26, 2005 Messages 592 Reaction score 70 Oct 12, 2018 #3 no. I think its 3 wires
brian6pac Legandary Member Legendary Member Joined Nov 15, 2016 Messages 5,668 Reaction score 4,091 Location N.E.Ohio Oct 12, 2018 #4 It has a internal regulator right ? then you should only need a ign on for the rotor just 1 wire and the big wire to the battery, look online and see if you can find a wiring diagram for it by the part #
Dubob FABO Gold Member FABO Gold Member Joined Oct 28, 2011 Messages 1,408 Reaction score 741 Location Ohio Oct 12, 2018 #5 Here’s the plug you have a power and sense wire that need connected. You might find the connector cheaper but this gives you a start and tells you what wire is what. Pigtail harness for Denso 210-0106 alternators | AR Engineering
A A/MP Well-Known Member Joined Nov 26, 2005 Messages 592 Reaction score 70 Oct 12, 2018 #6 That's it. THX
