Detroit Muscle windshield gasket & lock strip
Convertible A-Body Mopar
  1. BobW
    BobW Curmudgeon At Large FABO Gold Member
    475
    426
    Jun 26, 2020
    Central, FL 34705
    Local Time:
    8:13 AM
  2. Plymouth 65
    Plymouth 65 Floorable Deplorable
    1,649
    1596
    Jun 27, 2016
    Mich
    Local Time:
    8:13 AM
    Yes, Detroit Muscle has great products and support. I wouldn't hesitate to buy from them. 65'
    • Agree Agree x 1
    • BobW
      475
      426
      Jun 26, 2020
      Central, FL 34705
      Local Time:
      8:13 AM
      That was my first thought based on what I have read here on FABO.
      I did send a note asking if this is a Precision Products item (same part #) and if it's in stock.
      • Agree Agree x 1
      • 65 Dartman
        65 Dartman FABO Gold Member FABO Gold Member
        12,603
        4009
        Sep 24, 2006
        Strasburg, VA
        Local Time:
        8:13 AM
        I’ve bought quite a few early A-only products from them. All fit perfectly
        • Like Like x 1
        • 66340SEDAN
          66340SEDAN FABO Member #3649 FABO Gold Member
          21,906
          12324
          Nov 20, 2006
          Minnesota
          Local Time:
          7:13 AM
          BTW, DMT has awesome stuff and talked to them at the mopar show here and I suggested they make for for the early-a stuff and he said they were working on it....guess he was telling the truth!
          • Like Like x 1
          • BobW
            475
            426
            Jun 26, 2020
            Central, FL 34705
            Local Time:
            8:13 AM
            DMT confirmed it is the Precision set, ordered it along with a few other items!
            • Like Like x 2
            • Jim Kueneman
              Jim Kueneman FABO Gold Member FABO Gold Member
              2,103
              4251
              Jul 26, 2016
              Sonoita, Az
              Local Time:
              5:13 AM
              Just installed mine from DMT. Was a bit of work but fit perfectly. These are not quite right and if you call Jim at DMT he will give a an earful.. No one make a 100% correct seal for the convertible even if you see one that claims to be. The lip is a bit shorter than a convertible and it shows some of the frame from the outside. Paint around the glass area black and add a bit of black sealer and you will never notice.
              • Thanks! Thanks! x 2
              • BobW
                475
                426
                Jun 26, 2020
                Central, FL 34705
                Local Time:
                8:13 AM
                Thanks Jim.
                Got my gasket a few days ago and picked up a windshield on Wednesday.
                I saw the convertible vs hardtop gasket difference in another post.
                Good tip on painting the frame black.
                Did you install the gasket on the frame first, then work the windshield in? Or vice versa?
              • Jim Kueneman
                2,103
                4251
                Jul 26, 2016
                Sonoita, Az
                Local Time:
                5:13 AM
                Gasket then windshield. With the lock bead type it is easy. The hard part is getting the bead in. Heat the strip in the corners to minimize the chance of wrinkling the chrome.
                • Thanks! Thanks! x 1
                • BobW
                  475
                  426
                  Jun 26, 2020
                  Central, FL 34705
                  Local Time:
                  8:13 AM
                  That's pretty much what I had decided. I got the lockstrip tool and saw an install video on the Precision Products website.
                  Hoping to finish sanding this week and get it in primer.
                • Jim Kueneman
                  2,103
                  4251
                  Jul 26, 2016
                  Sonoita, Az
                  Local Time:
                  5:13 AM
                  Lockstrip tool?? More info please.
                • dibbons
                  dibbons Well-Known Member
                  5,088
                  3071
                  Nov 6, 2009
                  La Paz, B.C.S., Mexico
                  Local Time:
                  5:13 AM
                  My '65 factory service manual (page 23-65, windshield installation, AV models) recommends using "mineral spirits" as a lubricate to insert mylar trim strip. Never heard of a real person following such a procedure.
                • BobW
                  475
                  426
                  Jun 26, 2020
                  Central, FL 34705
                  Local Time:
                  8:13 AM
                  • Jim Kueneman
                    2,103
                    4251
                    Jul 26, 2016
                    Sonoita, Az
                    Local Time:
                    5:13 AM
                    • Like Like x 2
                    • BobW
                      475
                      426
                      Jun 26, 2020
                      Central, FL 34705
                      Local Time:
                      8:13 AM
                      Bringing this thread back as I finally have the car painted and most of the trim re-installed.
                      Windshield install is next, my question is do you use a butyl sealer on the gasket where it slips onto the frame pinchweld?
                      I bought a tube of butyl sealer back when I bought the gasket, just don't recall where to use it!
                    • dibbons
                      5,088
                      3071
                      Nov 6, 2009
                      Local Time:
                      5:13 AM
                      Not sure, but I believe this is a product that can be used in that area:
