[FOR SALE] Diamond Stroker pistons (408) 51026
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
What I have here is 7 YES 7 (51026) used pistons in what I call very nice shape. Sure there are a few side scratches that are on ALL used stroker pistons but with a quick clean-up could be going in the engine. I would usually order one piston from a Diamond dealer and have but right now I have two new sets on my shelf. These pistons cost around 800-850.00 NEW. Buy these 7 for 375.00 PLUS shipping from Freeport PA. 16229. Price includes 7 piston pins and Spiral locks are already installed in on side so you will need a 1/2 set available at Summit or piston dealer.
408 Flat Top 10.7:1 With 65cc Heads / Diamond Forged
  • Designed to fit most Mopar® O.E.M. open & closed chamber heads
  • Will work with aftermarket Edelbrock® & Indy® heads
  • May be used with small nitrous applications
  • Ratios figured for .018" deck @ 9.600"
  • Standard 1/16" x 1/16" x 3/16" ring package
  • Premium 8620 pins included
  • Gasket volume = 8.9cc
  • Top ring down = .290"
  • Max valve diameter = 2.070" intake & 1.625" exhaust
  • Valve relief depth = .292" intake and .224" exhaust
  • Made from strong 4032 material
  • For higher nitrous or blower applications request the 2618 piston material. (no extra charge but allow 1 - 2weeks lead time)
C.D.
Approx.
Weight
Pin Size CC's Comp 60cc Comp 65cc Comp 70cc Stroke
1.457" 495gr .984" X 2.750" -6.8 11.3 10.7 10.2 4.00"
Untitled by John Cadamore, on Flickr
