Disc brake conversion recommendations
Brakes for your Classic Mopar
  1. PWdart
    PWdart Member
    13
    0
    Jan 1, 2015
    Ohio
    Local Time:
    3:21 PM
    Just wondering who's using what to convert from front drum to power disc. Good experience? bad experience? 2 inch drop spindles? Or should I just find the factory stuff and maybe use a dual power booster just to save some room under the hood? This is for a 69 Dart
  2. Lonnie Leach
    Lonnie Leach Duster/ Valiant
    124
    46
    Oct 28, 2019
    Monroe Mi
    Local Time:
    3:21 PM
    I just put a pair of 73 a body's spindles on my 69 and used 73 caliper and hardware
  3. Lonnie Leach
    124
    46
    Oct 28, 2019
    Monroe Mi
    Local Time:
    3:21 PM
    You will have to change the Master cyl to a 80's dodge ram larger bore for disc..and the upper A arms for a 73 a body
    • Disagree Disagree x 2
    • hemi71x
      hemi71x FABO Gold Member FABO Gold Member
      5,554
      1917
      Dec 22, 2009
      Rancho Cordova, CA
      Local Time:
      12:21 PM
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      11,002
      5453
      Nov 28, 2008
      NorCal
      Local Time:
      12:21 PM
      Call DoctorDiff. He sells everything you need, the ‘73 up disks are the way to go. Not a lot of donors left running around though, and then you have to rebuild all of it anyway.
      No need to run power disk either if you use a 15/16” master cylinder. Way better pedal feel, and it’s really not that hard of a pedal with the right size MC.
      Larger bore master cylinder is a terrible idea. 15/16” is the way to go.
      That’s good set up if you want to stay SBP.
      Personally I wouldn’t bother with staying SBP I was already swapping spindles, more hassle than anything. But that’s just me.
      • Agree Agree x 4
      • Like Like x 3
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        4,963
        3058
        Jul 16, 2017
        Northern Colorado
        Local Time:
        1:21 PM
        Go stock. No booster needed.
      • Car Nut
        Car Nut Mopar Master
        16,726
        71787
        Dec 28, 2018
        Trump Train
        Local Time:
        1:21 PM
        • Agree Agree x 5
        • dano
          dano Evil Handy Man
          3,244
          1130
          Aug 22, 2005
          Gresham, Oregon
          Local Time:
          12:21 PM
          Depends. Are you looking to go LBP or keep the small? How do you intend to drive the car? What are your expectations?
        • 72Dart6pack
          72Dart6pack Harder Better Faster Stronger.
          3,707
          3485
          Feb 1, 2016
          Roseville Michigan
          Local Time:
          3:21 PM
          Photo is all Dr Diff parts. Nuff said. :)
          • Like Like x 3
          • dodge71demon
            dodge71demon Well-Known Member
            3,379
            521
            Apr 29, 2009
            Indiana
            Local Time:
            3:21 PM
            What part of Ohio are you from
          • Lonnie Leach
            124
            46
            Oct 28, 2019
            Monroe Mi
            Local Time:
            3:21 PM
            Well that's what is on mine and works well for me..
            Disagree if you like
          • PWdart
            PWdart Member
            13
            0
            Jan 1, 2015
            Ohio
            Local Time:
            3:21 PM
            near Cleveland
          • PWdart
            PWdart Member
            13
            0
            Jan 1, 2015
            Ohio
            Local Time:
            3:21 PM
            Streetcar with some dragstrip passes. Just was concerned about the fade with the drum brakes had a bad experience with one of my friends cars. Disc also seem to be better for a left right balance
          • PST
            PST Marketing Manager FABO Vendor
            890
            374
            Apr 22, 2009
            Montville, NJ
            Local Time:
            3:21 PM
            We offer a variety of conversion kits for both power or manual set ups. We offer a kits that converts to the 73-76 setup or kits that retain the stock drum brake spindles from wilwood or leeds brakes and as a member of the forum we offer 10% off orders of $200 or more and free shipping. Here is a quick link to the conversion kits on our site.
            PST | Disc Brake Conversion | Disc Brake Kit | Disc Brakes
            Thanks
            James From
            PST
          • PWdart
            PWdart Member
            13
            0
            Jan 1, 2015
            Ohio
            Local Time:
            3:21 PM
            thank you. Nice kits. Are the rotor replacements available at a typical parts store?
          • PST
            890
            374
            Apr 22, 2009
            Montville, NJ
            Local Time:
            3:21 PM
            Yes depending of the kit we can provided you the replacement part numbers
            Thanks
            James From
            PST
          • PWdart
            PWdart Member
            13
            0
            Jan 1, 2015
            Ohio
            Local Time:
            3:21 PM
            Excellent. Future parts availability is important
          • mbaird
            mbaird mbaird
            6,132
            3003
            Dec 10, 2005
            boise, Id
            Local Time:
            1:21 PM
            I went with 73 A body disc up front and Cherokee discs in the rear on my Fastback.
            Stops with little effort..... but honestly I dont drive fast enough to need them .
            The 69 340 Swinger is staying stock with drums all around. I did use smaller diameter master though. Havent driven it yet... we shall see how it stops.
          • AndyF
            AndyF Well-Known Member
            1,743
            1827
            Feb 23, 2009
            Oregon
            Local Time:
            12:21 PM
            I went with Viper brakes on my Duster.
            • Like Like x 1
            • Jimacuda
              Jimacuda Well-Known Member
              1,847
              614
              Nov 10, 2006
              Phoenix AZ
              Local Time:
              12:21 PM
              72 Demon...FMJ body front discs and late B 11" rear drums w 15/16" master.
              No power assist.
              Works beautifully, stops fast and it's consistent/predictable.
              • Like Like x 1
              • Lonnie Leach
                124
                46
                Oct 28, 2019
                Monroe Mi
                Local Time:
                3:21 PM
                What size bore u think a 80 non power is? has 15/16 bore
              • BigBlockMopar
                BigBlockMopar BigBlockMember
                1,754
                755
                May 1, 2011
                Netherlands
                Local Time:
                9:21 PM
                There's also the brake-pedal ratio to be considered.
                IMO, a manual system has a numerical larger (underdash) brake-pedal ratio than a power brake system.
                I run a 15/16 MC on a ('73 factory) power brakepedal system.
                2.75" ø C-body calipers.
              • Gregor
                Gregor Well-Known Member
                94
                75
                Nov 1, 2016
                Cleveland, Ohio
                Local Time:
                3:21 PM
                I have a 70 Dart and am planning on doing a front disc upgrade in the spring. I too live in Cleveland. Maybe we share notes on this project. I want to keep my 14 inch sbp wheels for the stock look.
