Disc BRAKE issuE- loosing pressure BUT WHERE>?
Brakes for your Classic Mopar
  1. BIG-B-Barracuda
    BIG-B-Barracuda Well-Known Member
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    Talking Disc BRAKE issuE- loosing pressure BUT WHERE>?
    1968 barracuda front disc brake conversion 73+ Abody set up.
    power steering
    brake booster with DUAL compartments rear drum front disc.
    front reservoir loosing oil somewhere, have to refill every 3 weeks/month - traced the line from booster/ reservoir to lines to discs and found no leak....
    whats my issue?
    bad booster? bad reservoir? :burnout::burnout::burnout::burnout::burnout: :banghead:
  2. 6pk2goDemon
    6pk2goDemon Mopar Mod Staff Member FABO Gold Member
    11,454
    2600
    Mar 1, 2008
    Arizona
    Local Time:
    10:13 AM
    The front reservoir should be the smaller one and for the rear brakes. Pull the drums & check the wheel cylinders, rear hose, lines etc....
  3. Johnny Mac
    Johnny Mac www.blueprintengines.com FABO Vendor
    3,466
    2456
    Jul 10, 2010
    OHIO
    Local Time:
    1:13 PM
    Well it doesn't evaporate, so it's leaking somewhere. Perhaps out the piston inside the caliper...making it harder to see? Since you don't see any obvious leaks at any fittings, or your caliper hoses?
    a booster doesn't hold fluid...so no
    the only place on the res it can leak is out the fittings on the side, or the top cover seal. again it's got to be going somewhere. are you positive the front res is the front brakes?
  4. BIG-B-Barracuda
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    FRONT RESERVOIR IS Rear drum brakes! of course i'm a moron thanks you.
    i will go home and pull the drums and check that thanks! it just started happening two months ago. had to re fill twice now.
    should be an easy fix if its just the wheel cylinder.
    i will keep you guys in mind if anything comes up.
  5. mopardude62
    mopardude62 FABO Gold Member FABO Gold Member
    671
    506
    Oct 3, 2011
    Liberty, MO
    Local Time:
    12:13 PM
    I just recently had this happen to my Dodge truck. I was losing fluid and couldn't find a leak or see any fluid on the firewall, booster or the outside of the master cylinder. It wound up being a small hole in the booster diaphragm, the master was leaking into the booster and the fluid was being sucked into the intake and burned. I installed a new booster and master cylinder, problem solved.
  6. BIG-B-Barracuda
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    no obvious leaks maybe it is inside, correct. apparently:blob: the front smaller reservoir is for the rear so my mistake i will go home and check rear cylinder. thanks guys.
  7. BIG-B-Barracuda
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    got it. thanks
    i will try the rear cylinders first if thats not it i will look into this.
    but i hope that this is not my issue. :prayer: thanks
  8. Mopar Tim
    Mopar Tim FABO Gold Member FABO Gold Member
    18,680
    11256
    Nov 29, 2014
    vista CA.
    Local Time:
    10:13 AM
    This is only possible if the rear reservoir is losing fluid. :burnout: common.
  9. Mopar Tim
    18,680
    11256
    Nov 29, 2014
    vista CA.
    Local Time:
    10:13 AM
    Look UP^^^^^^^^:burnout:
  10. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    15,904
    4953
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    1:13 PM
    If you can't find a wheel cylinder leaking (which I think you will), and you have power brakes, pull the master cylinder off off the booster and see if it is wet at the piston.
  11. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    17,591
    5988
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    12:13 PM
    BigB............It seems you have more than your fair share of stuff going wrong. You have my sympathies.
    Good luck
  12. BIG-B-Barracuda
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    Any one know where I could find those drum cylinder/Pistons?
    Part numbers?
    The rear reservoir is not loosing oil...
    The front one loosing a lot and pedal pressure is very low to floor board makes me think if front discs are even working...
  13. BIG-B-Barracuda
    1,130
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    12:13 PM
    Thanks AJ I already feel the Good vibes from you guys - thankfully all these things are small easy fixes ! :cheers:
  14. mderoy340
    mderoy340 Well-Known Member
    2,212
    968
    Aug 2, 2012
    Melbourne FL
    Local Time:
    1:13 PM
    Autozone has the wheel cylinders for about $8
  15. RedFish
    RedFish Well-Known Member
    23,902
    2602
    Sep 5, 2007
    Local Time:
    12:13 PM
    Before dealership service dept' I worked for a tire/auto service center. Looking for tell tale signs on backing plates, inside wheels, streaks on back of tires, became a habit.
    Peek under the back of a customers car and say, "you have a wheel cylinder leaking here". And their response was often, "How can you tell ?"
  16. 2 Darts
    2 Darts A-body Addicted
    3,480
    211
    Mar 28, 2008
    In a house
    Local Time:
    12:13 PM
    Tell tales for me have been streaks on the inside tire sidewall and smoke when braking. LOL
