Disc brake spindles
qkcuda
Jarvis, Ontario
Can someone confirm whether the spindles for 10 inch drum brakes are the same as the ones for the Kelsey-Hayes disc brakes?
Thanks, I knew the 9 and 10 inch drum ones were different, but wasn't sure on the discs.
Strange race brakes use the 9 inch drum spindles
Wilwood uses the 10 inch drum spindles.
conversion kits also use the 10 inch drum spindle
Factory 4 piston Kelsey Hayes are on their own
Yes I had a conversion set on the 10 inch drum spindles, but the fellow that bought my car wants to go back to 4 inch bolt pattern.
