What Summit kit number ? If it was not factory, somebody cobbled it or it would be over the counter parts.
What was there kit number. What did you order the kit to fit exactly ? Why no direct answers ?
Trying to "guess" what you bought.
So rereading the first post " everything is new in the rear as well" What does that mean ? Factory original new parts ? Rebuilt? Calipers, rebuilt master cylinder, rebuilt wheel cylinders ? Or "new" US made preferably by a major brake manufacturer.
You never gave any details only what you tried ?
Rebleeding doesn't do anything unless there is air in the system and you would know it because the calipers would not stick, the pedal would keep going down because air compresses and fluid does not.
Here are some links to Factory Service Manuals. I don't know what year your "kit" is for so download the proper year and go to the brake section.
This is Factory information. Never, ever use a rebuilt M/C.
Almost every time we had a brake failure in the shop after a M/C change. It was a rebuilt unit.
We no longer installed anything other than a quality, new Master cylinder.
It is literally the heart of the brake system. When it fails, you car literally has a Heart attack(brake failure).
Sticking brakes that are not caused my improper installation will be a hydraulic blockage. eg Valve, debris, etc.
Always use a new, unopened bottle of premium brake fluid. Flush entire system. Did th the third brake line and block get replaced as well ? No Import parts from the East ?
From the west is ok Germany, Europe atc...
Click Here----------------------->
Service Manuals – MyMopar
