Disk Brake Swap - Brake Pushrod Question
cudakid67
Riverside, IA
Swapping 73-76 power disk setup on my 67 barracuda. I have the original manual brake pushrod. I'm guessing it is too short, can someone point me in the right direction of the correct pushrod I need for my power brake master cylinder.
Get a adjustable one think Dr. diff has them in assorted sized just measure it close and get that range.
The POWER disc linkage doesn't use a pushrod. It uses a swivel linkage setup. The one on the 73-76 will work just fine if you use the corresponding booster.
That's what I was thinking. Unfortunately I don't have that part, I just have my old pushrod. Is the swivel linkage setup available from any suppliers?
I've had several of them but I'm out.. they come on every power brake setup on 73-76 A bodies. I'm certain an FABO member can fix you up with one
