[WANTED] distribution blocks drum brake cars
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Need two for 64 Belvedere and 62 Dart both B bodies but all the same I bet for A or B drum brake cars. Yes I know Inline Tube has new ones for $35 ea but good used will be fine. Had some but used up. No bone yards around here with old stuff.
Just wondering if anyone has some they can ship??
I have a 65 a body single pot drum-drum
this one?
ive got a couple.
I have one from my old '65 Belvedere..... Been in my brass part collection for poss. 20 years! Let me know if your interested & I'll send you pictures of it.
Your 62 & 64 had single reservoir master cylinders, what you need is the later distribution block for a dual reservoir drum brake system. There was a discussion about the early drum brake versus disc brake blocks here about a week ago that showed pictures.
I dug threw enough box of parts that I found some dual dist. blocks. What models who knows but I needed block to correspond to the pre bent lines so I just ordered their block I hate flanging brake line with my sorry flanging tool.
I bet all disc brake systems also use a proportioning valve.
Yes, there is a distribution block with a built in proportioning valve, but that isn't what you need. I think C bodies & some trucks starting in 66-67 had the dual bowl master cylinders. As far as getting one to fit up to factory bent lines is going to be a REAL shot in the dark.
