Distribution valve and or Proportioning valve,
Wdstk@69
Member
Fairland-Indiana
Is it necessary to install a distribution valve for the brake lines or can I just run the brake lines direct from the master cylinder to the front and rear brakes using a "T" to connect to the left & right wheels.
If doing the above should I install a Proportioning valve for the rear brakes, it is a 66 Plymouth Valiant that I did a front and rear disk brake conversion.
* Also, is the front smaller reservoir on the master cylinder for the front brakes and the rear larger reservoir for the rear brakes ?
Thanks in advance for your help,
Large rear reservoir is for front brakes (discs require a larger volume) and front reservoir is for the rear brakes.
Yes, you can plumb the rear reservoir into a "tee" fitting for the front brakes, and the front into an adjustable proportioning valve for the rear brakes.
