Distributor Gasket for 1973 225ci Slant 6?
Witchboard
Oklahoma City
Had to pull my distributor to replace the vacuum advance. When I pulled it off, it had what looks to be a home made gasket. I checked the manual and I'm only seeing an o-ring. Is it supposed to have a gasket between the block and distributor?
No gasket, but should have the "O" ring in your picture, and also a larger "O" ring right up at the adjuster plate. Someone probably had a oil leak and didn't have the large "O" ring.
