distributor question
Electrical and Ignition
  1. texas360
    texas360 Well-Known Member
    379
    82
    Jan 30, 2016
    TEXAS
    Local Time:
    8:34 AM
    I'm finishing up my mild 360.. I'm going to switch over to a MSD Streetwise box versus the factory ecu and ballast... what is a good distributor to run with this? also coil choice. should i go with a stock vacuum advance, aftermarket vacuum advance or go with an aftermarket mechanical advance? I'm still learning so be easy on me
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    60,427
    26590
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    8:34 AM
    @halifaxhops has a sun distributor machine and restores distributors... He can set up a nice stock distributor that will run nice...
    Here's one that he set up for my buddy Eddie's Dart with a mild 340 and stock electronic ignition...
    This isn't brake torquing, just stomping the pedal from idle....
    • Like Like x 3
    • texas360
      379
      82
      Jan 30, 2016
      TEXAS
      Local Time:
      8:34 AM
      you running a vacuum advance or mechanical? killer car,,, sounds awesome
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      69,573
      39950
      Jan 20, 2014
      Hoppyworld, PA
      Local Time:
      9:34 AM
      He has a vac advance. It is just set up with the right curve for the engine. Makes a Huge difference like you see.
      • Agree Agree x 2
      • Like Like x 1
      • krazykuda
        60,427
        26590
        Aug 20, 2007
        Orland Park, IL
        Local Time:
        8:34 AM
        Vacuum advance on the distributor...
        600 vacuum secondaries on the carb....
        • Like Like x 1
        • Oldmanmopar
          Oldmanmopar Going left turning right FABO Gold Member
          9,483
          6369
          Jan 8, 2009
          Danielsville Pa. 18038
          Local Time:
          9:34 AM
          you can use a factory electronic Dist. with Vacuum advance or without using a lean burn plate and block off. The newer mopar performancce dist. has an adjustable mechanical advance with two screws. If I was just looking for a decent Dist. at low cost. Pro Form, Or spend the $$$ MSD billet with bearings for rpms to and above 8000. and a digital 6 with coil.
          • Like Like x 1
          • yellow rose
            yellow rose Overnight Sensation
            28,501
            25174
            Jun 19, 2015
            Central Washington
            Local Time:
            6:34 AM
            I just had that exact MSD box fail on my test bench. Should be getting it back from MSD soon. They will send a report with what they had to repair. That’s the third new MSD digital box I had fail. The first two had the same repair. It will be interesting to see if box number 3 failed the same component.
            • Agree Agree x 1
            • halifaxhops
              69,573
              39950
              Jan 20, 2014
              Hoppyworld, PA
              Local Time:
              9:34 AM
              • Agree Agree x 1
              • Oldmanmopar
                9,483
                6369
                Jan 8, 2009
                Local Time:
                9:34 AM
                I have two of these from years ago. Offered them on here a while back on a thread similar to this. I had no reasonable offers. Sure I was offered $15 shipped so I kept them as wall hangers. They are out there you just have to look. I only use MSD. When you run these mopar boxes and a ballast resister you need to keep spares in the glove box.
              • texas360
                379
                82
                Jan 30, 2016
                TEXAS
                Local Time:
                8:34 AM
                i run the original orange box on my current built 318, but am wanting to not only clean up wiring in the bay i also wanted upgrade the ignition for the 360, the box will allow me to eliminate the ecu, ballast and some of the un needed wiring
              • Oldmanmopar
                9,483
                6369
                Jan 8, 2009
                Local Time:
                9:34 AM
                MSD has a ready to run unit. I know they make a pertronix unit. But then you need to use your distributor. Check its condition before going that route.
              • texas360
                379
                82
                Jan 30, 2016
                TEXAS
                Local Time:
                8:34 AM
                see everything i have read from people they say the Pro Form and the Speedmaster Distributors are junk
              • halifaxhops
                69,573
                39950
                Jan 20, 2014
                Hoppyworld, PA
                Local Time:
                9:34 AM
                Thats a good one if you can find a ballast for it at a decent price. I missed that up for sale.
              • yellow rose
                28,501
                25174
                Jun 19, 2015
                Central Washington
                Local Time:
                6:34 AM
                I thought all those boxes with that part number were gold???
                • Disagree Disagree x 1
                • texas360
                  379
                  82
                  Jan 30, 2016
                  TEXAS
                  Local Time:
                  8:34 AM
                  what book is that reference from? i would be interested in finding the book
                • halifaxhops
                  69,573
                  39950
                  Jan 20, 2014
                  Hoppyworld, PA
                  Local Time:
                  9:34 AM
                  One of the old 70 MP books I believe.
                • halifaxhops
                  69,573
                  39950
                  Jan 20, 2014
                  Hoppyworld, PA
                  Local Time:
                  9:34 AM
                  Since we are on this I am testing a bunch of ECU's on my tester I made and tell you what I think the trick to these are having the PROPER ballast matched to the ECU. Most just throw a one ohm in and forget it.
                  • Agree Agree x 1
                  • Oldmanmopar
                    9,483
                    6369
                    Jan 8, 2009
                    Local Time:
                    9:34 AM
                    I believe I have the ballast's . Now I'll have to look and keep them together . Learned something.
                  • halifaxhops
                    69,573
                    39950
                    Jan 20, 2014
                    Hoppyworld, PA
                    Local Time:
                    9:34 AM
                    Most FSM's have the ballast values in them. Really looking into the reason of the high fails on them. I made a red neck simulator I hook up along with the dist machine. Interesting results to say the least.
                  • Bewy
                    Bewy Well-Known Member
                    1,312
                    821
                    Jan 1, 2021
                    Australia
                    Local Time:
                    1:34 AM
                    When you say 'mild' 360, is the cam larger than stock. If so, a stock vac adv unit will most likely be erratic in operation with the reduced vacuum. This is a common problem & VA gets the blame when the real culprit is the person who is doing the job does understand the parameters involved.
                  • texas360
                    379
                    82
                    Jan 30, 2016
                    TEXAS
                    Local Time:
                    8:34 AM
                    Specs on engine
                    360 bored 0.060
                    Stock crank, rods, dished pistons
                    Hughes whiplash cam
                    Adjustable 273 rockers
                    Sidewinder aluminum heads(171 intake runners, 63 cc chambers)
                    Port matched Wieand Stealth imtake
                    Holley 650 dp
                    2600 stall
                    Reverse manual 904
                    8.25 rear open with 3:55
