rustytoolss
Should I use manifold or ported vacuum to my distributor ? Also I'm using a 1982 Thermoquad, which port would that be ? Thanks
Ported vacuum, There may not be a ported vacuum tap on an 82 TQ. Ported is usually a horizontal slot in the throttle bore.
I cannot imagine that there would not be
Think Lean Burn...
OK, do you REALLY want a lean burn carb anyhow?
yes, you want ported vacuum. Lean Burn carbs did not have ported vacuum. I hope yours does.
