Do I have reason to be concerned???
Mopar General Discussions
  1. MOPAROFFICIAL
    MOPAROFFICIAL FABO Gold Member FABO Gold Member
    8,667
    7925
    Jun 1, 2016
    Oceanside ca.
    Local Time:
    2:47 AM
    Go over it with some 600 grit, if the blue comes off...who cares.
    • Like Like x 1
    • Agree Agree x 1
    • moper
      moper Well-Known Member
      15,929
      2060
      Dec 27, 2004
      eastern CT
      Local Time:
      10:47 AM
      Agreed - and I'll add "...or a cut off wheel and chisel."
      It never got hot enough to glow. But there are areas that got higher localized temps than I'd ever want to see in a hardened part. If that was a repair to get things rolling again I'd run it and see what happens. If it bent you'll know it. If this is a performance car that's going to get some abuse, I'd probably replace it.
    • JDMopar
      JDMopar Well-Known Member
      4,183
      3142
      Jan 19, 2012
      Candler, NC/Myrtle Beach, SC
      Local Time:
      5:47 AM
      Mike....what axle is that? If it’s a stock 8 3/4 A body axle, I can fix you right up! I have a onesie I would gladly give you if that’s what it is. The one I have is 27 7/8 from wheel mounting flange to end of axle, has RH 7/16 wheel studs, and the bearing is already removed. I robbed the adjuster for an E body years ago. Bearing surfaces and splines look good, but it could use a good soak in vinegar for a day or 3.
      • Like Like x 1
      • cudamike13
        cudamike13 cudamike13 FABO Gold Member
        611
        530
        Sep 19, 2010
        Mineral Bluff Ga
        Local Time:
        5:47 AM
        Thanks, but no it is a b body rear.
        I am probably just going to get new ones.
        How r u doing. I'm slowly getting over this GCA I have.
      • JDMopar
        4,183
        3142
        Jan 19, 2012
        Local Time:
        5:47 AM
        Doing great, thanks. I was hoping that it would work for you. Measure from the wheel side of the flange, to the end of your boogered up axle. I have a set of B body axles, but there were 2 or 3 different lengths between 65 and 70 model 8 3/4's. I can check to see if mine are the same, and hook you up if they are.
        :thumbsup:
      • Treblig
        Treblig Well-Known Member
        7,272
        4727
        Oct 5, 2013
        South Texas
        Local Time:
        4:47 AM
      • Jadaharabi
        Jadaharabi FABO Gold Member FABO Gold Member
        8,934
        10199
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        4:47 AM
        Here are a couple pictures as an example of what a grinder does to a spindle by somebody that doesn't know how to take off a frozen bearing.
        I would say between the grinder and their hammer and chisel they did a pretty good job of screwing up the Seal surface and the spindle surface where the bearing rides. All because they didn't know how to do it correctly. They are what I call a Hammer Mechanic.
      • Dartswinger70
        Dartswinger70 make it 3 yards and well have us a automobile race
        3,042
        1583
        Sep 20, 2005
        Southeastern Pa.
        Local Time:
        5:47 AM
        Used to say you can messt things up with a torch and an air chisel if you dont know what youre doing. yes, if removing a bearing race it gets cut then rapped with a chisel to split it the walked off with an air chisel.
      • cudamike13
        611
        530
        Sep 19, 2010
        Mineral Bluff Ga
        Local Time:
        5:47 AM
        Dr Diff to the rescue!
        Now I can get moving again!
        • Like Like x 5
        • pittsburghracer
          pittsburghracer FABO Gold Member FABO Gold Member
          5,741
          10785
          Apr 20, 2016
          Freeport, PA.
          Local Time:
          5:47 AM
          Sometimes when I see guys using heat to remove something I want to grab the torch out of their hands. First of all we aren’t burning it off so a nice, calm, quiet torch setting is used. Just crack the oxygen on and adjust the flame. Heat goes ONLY on the part being removed. Not the part you are pulling it off of. It’s probably only a .001 shrink fit at the most.
        • fratzog lover
          fratzog lover Well-Known Member
          15,788
          15165
          Jun 7, 2013
          Northeast Alabama
          Local Time:
          5:47 AM
          "Voila" and "Yahtzee" in the same video.
