Do you have rods in your head? I do.
Slant 6 Engines
  1. Wayne's World
    Wayne's World My World, My Universe, My Garage
    32
    34
    Nov 21, 2021
    MD
    Local Time:
    10:52 PM
    Yep. If they are small enough I pull them out but most of the time they appear to be stable so I leave them alone.
  2. volaredon
    volaredon Well-Known Member
    1,101
    347
    Feb 28, 2010
    IL
    Local Time:
    9:52 PM
    Ive seen this posted and talked about somewhere not too long ago/ don't remember whether it was the /6 forum or the copy of Dutra's book I have.... I'm thinking it may have been both. but it was mentioned wherever it was, to go ahead and pull them out with needle nose.
    In fact I probably wouldn't have noticed (or looked) in the heads that I have here if I hadn't seen the writeup that I did about the subject,
    When I 1st tried to pull them I thought the same thing, "they're REALLY in there", won't come out... but then I tried again (from a different water passage maybe?) and got one to move/ so I started pulling and it twisted itself up and came right out. They weren't very sturdy or rigid.... probably on account of how old they are and the exposure to water, coolant, and what it turns into when neglected plus throw in all the heat and cooling cycles over the years.....
    there was a thread somewhere else recently, claiming that someone discovered the rods in their /6 head when their car wouldn't warm up and discovered one wedged in their thermostat, keeping it from closing..... given the way coolant flows and moves I can see them floating around in there eventually. If possible I'd try and get them outta there.
  3. Killer6
    Killer6 Well-Known Member
    3,018
    1121
    Mar 9, 2015
    PA
    Local Time:
    9:52 PM
    No, they manage that with the head gasket having intentional restrictions at the coolant passages.
    • Agree Agree x 1
    • Killer6
      3,018
      1121
      Mar 9, 2015
      PA
      Local Time:
      9:52 PM
      The uphot is, every Slanty head ever made has 'em, over a million of 'em. Runnin' & runnin'.
    • cruiser
      cruiser Well-Known Member
      421
      454
      Feb 26, 2016
      Bloomington, MN
      Local Time:
      9:52 PM
      Good point, Killer6. But it still bugs me. Something foreign in my cylinder head. It wouldn't be that tough for the guys to pull them out back when they were cast. Just seems lazy to me.
    • Ironracer
      Ironracer Gearhead
      3,277
      2390
      May 8, 2020
      Tampa Bay Florida
      Local Time:
      10:52 PM
      Seem to remember " blood" in the late 70s, odd, we were not close to driving... 4th or 5th grade...
    • Killer6
      3,018
      1121
      Mar 9, 2015
      PA
      Local Time:
      9:52 PM
      I
      I feel Ya, but that's mass production, & the processes used at the time. Now, lost-foam method & others, have increased quality & control over the casting process. As stated by another member, it wasn't uncommon to have a bit of wire exposed during pattern filling, or during the pour. That is welded into the casting at that point. Imagine pulling hot castings out of the box, to bury/let cool, then knocking the green sand out. Cars are rolling down the line, the machining station is waiting for the raw casting, & someone is wrestling w/a pair of pliers on a wire that is part of the casting. Probably get kicked out of the process rather quickly, being that they were intended to be left there to begin with.
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      81,511
      61120
      Jun 7, 2010
      Georgia
      Local Time:
      10:52 PM
      uhhhh no. Anything that slows water flow down coming out of the engine will not cause it to run cooler, but quite the opposite.
    • RustyRatRod
      81,511
      61120
      Jun 7, 2010
      Georgia
      Local Time:
      10:52 PM
      Red Asphalt. 1964. We saw the original I would "guess" sometime in the late 70s.
      https://www.imdb.com/title/tt3207326/
      Here's a short list of some of the scare movies used in driver's ed.
      Driver's Ed: A History And List of Scare Films
      Dig the cool DODGE driving simulator. I didn't see Blood on the Highway there, but I remember it well.
    • Swinger 340
      Swinger 340 Well-Known Member
      98
      65
      Jun 9, 2021
      Lake Placid, Florida
      Local Time:
      10:52 PM
      Maybe I'm missing something. Water flow coming out of an engine would be the same as going into the engine. So slowing down the flow some would allow the radiator more time to cool the incoming flow to the engine. A larger radiator works well, why, water is being cooled longer.
    • banzaibullitt
      banzaibullitt FABO Gold Member FABO Gold Member
      28
      29
      Oct 2, 2021
      Minnesota
      Local Time:
      9:52 PM
      I was wondering what that was. I was able to get a loose piece out while I was replacing the thermostat, water pump, and hoses last summer.
    • volaredon
      1,101
      347
      Feb 28, 2010
      IL
      Local Time:
      9:52 PM
      Looks downright nasty in that head
      • Agree Agree x 1
      • banzaibullitt
        28
        29
        Oct 2, 2021
        Minnesota
        Local Time:
        9:52 PM
        I did a cooling system flush when I was done.
      • Tech857
        Tech857 Well-Known Member
        235
        67
        Jun 29, 2012
        NH
        Local Time:
        10:52 PM
        That larger radiator works better because it has more surface area to reject heat. More tubes more fins ect.
      • CNC-Dude
        CNC-Dude Well-Known Member
        128
        74
        Apr 6, 2019
        North Georgia
        Local Time:
        10:52 PM
        Those support rods are in virtually every block and cylinder head from Chevy, Dodge and Ford that has ever been cast all the way back to the Model T. Modern casting techniques have eliminated the need for them, but they don't affect the cooling in any way. So other than them looking gnarly inside the water jacket there's nothing to be concerned about.
      • Swinger 340
        98
        65
        Jun 9, 2021
        Local Time:
        10:52 PM
        Not true CNC-Dude, I have found a rod stuck into a thermostat once. Did not know where it came from. Thanks to this thread, now I know. I'm 66 and still learning.
      • CNC-Dude
        128
        74
        Apr 6, 2019
        North Georgia
        Local Time:
        10:52 PM
        Well, for the most part, nothing to worry about! There probably are isolated incidents where there have been hiccups like yours, but the engineers apparently weren't too concerned with it or they would have had them removed before installation I would think.
      • A56
        A56 MoPar Affliction
        5,828
        15847
        Jun 24, 2014
        White Oak, N.C.
        Local Time:
        9:52 PM
        I found this on the internet about engine block casting techniques. No one here has stated whether the rods that they've seen in their blocks are steel or aluminum.
        The core shown below provides the space for water jackets around the cylinders. The core has being painted to seal the gas formed during the casting process within the core. And the pink colored ends are not painted to let the gas escape to the out side. Aluminum reinforcing rods are used to give more strength to the core. These rods get melted due to the molten metal poured during casting.
        • Like Like x 1
        • CNC-Dude
          128
          74
          Apr 6, 2019
          North Georgia
          Local Time:
          10:52 PM
          The ones I have seen in the Chrysler and Ford blocks and heads are steel. Haven't seen too many in Chevy's but they did use them also. On some Ford blocks, you can knock out the freeze plugs and see them extend up into the deck surface.
        • 67belevdere/225
          67belevdere/225 Well-Known Member
          136
          20
          Feb 23, 2017
          montreal
          Local Time:
          10:52 PM
          just notice that today in my head , its pretty solid in there, and its been over 50 years so she gonna stay like that
        • Killer6
          3,018
          1121
          Mar 9, 2015
          PA
          Local Time:
          9:52 PM
          I've only seen steel wire so far. The melting point of Al-U-minimum is <1/2 that of cast iron, & it has the propensity to transition from solid to fluid abruptly, the chances of a fragile core collapsing during the pour would be high IMO.
        • 67belevdere/225
          136
          20
          Feb 23, 2017
          montreal
          Local Time:
          10:52 PM
          here's mine very solid , I will attempt to see if it moves . but think she gonna stay there
        • Scooper
          Scooper Well-Known Member
          71
          25
          May 21, 2021
          Douglas, Georgia
          Local Time:
          10:52 PM
          Hey now, at least we're not as strange as poly-guys.
