[SOLD] Dodge Big Block Supercharger
Standonit1972
Atlanta
I am selling a new low deck torqstorm Supercharger Setup. It was used for mock up only, it’s never been run. I have everything needed to mount it to a low deck, including belts. I am asking $2600 for it. I also have a snow performance stage 2 methanol kit with the larger tank for sale. It’s also new, never removed from the box. I am asking $525 for all the snow performance stuff. And lastly I have a super sniper stealth 650hp setup for sale.I mounted the throttle body to mock it up but it’s never been run. I have the 650hp kit, plus the cd box, sniper coil, and a sniper dual sync distributor. I also have a couple of extras to ease the install. I am asking $1400 for the setup. I will sell it all as a package deal for $4k. Shipping would be extra.The headers are tti low deck 2 1/8 step headers with a 3.5 collector. They have been coated. I have a pending sale on the supercharger and snow methanol set up. Super Sniper and Headers still available.
Here you go.
I also have a lot of other parts that will be up for sale as I move to a 440. I have a 383 shortblock, tti headers, an Edelbrock Rpm Intake, msd Btm, and much more. The 383 is still in my dart, and runs well, and it doesn’t use oil.
The only things I have for a small block would be the 750 double pumper modified for blow through, and the msd Btm Setup. And the sniper without the distributor.
Hi there, great deals there. Quick question. If your converting to a 440 RB, why not use the supercharger on it? It should mount up in same location as the b-engine.
The brackets are different for a low deck and tall deck. You bolt the main bracket to the head but the other brackets utilize holes in the front of the block and water pump. Plus the engine I am going to run is a high compression engine, too high for supercharging unless I went to E85.
