Dodge Dart Fiberglass fenders
mickey
nova scotia
Will 1973 Dodge Dart fiberglass fender fit on a 1969 Dodge Dart. Are they same fender?
Yes, you can.The position of the headlamp bucket is different on metal ones. Can't say if that is the case on fiberglass.We put a 73 fender on a 67 and the headlamp was slightly off when we installed the headlamp/grille trim.I believe to the inside. it's been years ago.
The side marker light hole is different if that matters. The fiberglass fender might not have a side marker hole in it though.
Yes, it fits
The driver grill side may need a half inch spacer as some later years had a bit of a drop down where it mounts. I have a 69 and used a newer fender and had to do that to keep grill level
