I have a 1976 360 that has been running fine for years but is RPM limited.
It is a standard bore mill with #308 heads that were rebuilt. The heads have maybe 1000 miles on them in 20+ years so they should not be worn out. I installed them with the original valve springs from the truck engine that the heads were on.
It has a Weiand mid rise 4 barrel intake with a Mopar Performance 280/474 camshaft that runs quite strong out of the hole but runs out of breath early. I suspect the valve springs are weak, allowing valve float.
I saw a guy post this chart....
The very first on the list, #...0933 shows 115 lbs closed, 310 open. That is the spring listed for the 474 lift this cam has.
I have a set of springs I pulled off a set of Edelbrock BB heads, 1.55 OD. They were great but I needed to change them due to a switch to a roller cam. I'm curious if I can repurpose these springs into this 360 to eliminate the valve float.
The engine is on a stand and needs some attention before I install it in another car.
