DOH!!! Trans is good but.......
Richie
Kelowna BC Canada
I took my Dart a 69 in to get the 904 rebuilt. It works fine but now the suspension squeaks like the bajesus and one side seems stiffer than the other. What the F did he do? Do you need to take the torsion bars out to drop the transmission? Before the suspension was perfect, so quiet not a sound :(
Maybe while he had it up and the wheels were hanging down maybe both shocks finally called it quits?
There should not been anything removed except the trans and drive shaft. Where is the noise coming from... around the lower control arm bushings? You don't think he dropped the K-member (with motor and trans attached) from underneath the car do you? If he did sounds like he didn't install it back together correctly. He most likely didn't do it that way but people don't surprise me anymore.
I phoned him and he said all he did was take it for a test drive. He didn't sound weird or anything. Also when I picked my car up he said bring it back if I had any problems so that doesn't sound like
