Door alignment after subframe connectors?
Suspension, Steering and Chassis
  1. frederick_76
    frederick_76 Well-Known Member
    731
    163
    May 2, 2010
    Milton, Wa.
    Local Time:
    1:28 AM
    Anyone run into an issue with doors not aligning after installing subframe connectors? Its just my passenger side, the drivers side looks great.
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    36,026
    18153
    Jan 18, 2006
    Iowa
    Local Time:
    3:28 AM
    You should rebuild hinges, adjust and then weld in the sub frame ties.
    • Agree Agree x 1
    • JBurch
      JBurch Well-Known Member
      1,595
      702
      Oct 17, 2009
      Owego, NY
      Local Time:
      4:28 AM
      Yup, happened on my Barracuda when I did them; I figured 2 things, uneven garage floor and flimsy body. I realigned door.
    • OL DODGE
      OL DODGE Well-Known Member
      184
      71
      Mar 25, 2012
      Fairview Park,Ohio
      Local Time:
      3:28 AM
      you DID weld them in with the suspension loaded ,right?
      • Like Like x 2
      • Agree Agree x 1
      • famous bob
        famous bob mopar misfit
        11,469
        2899
        Aug 14, 2011
        okla
        Local Time:
        3:28 AM
        I didn`t want any built in ,uneven body twist welded in mine. I leveled the jack stands on my uneven garage floor, before welding. Why weld something up crooked , or warped !?! If u level it before , u can always readjust the doors if u need to.
        • Agree Agree x 1
        • frederick_76
          731
          163
          May 2, 2010
          Milton, Wa.
          Local Time:
          1:28 AM
          I did not do the work, I had it done.
        • Dusterdenovo
          Dusterdenovo Contentedly Old School FABO Gold Member
          813
          1346
          Dec 10, 2011
          British Columbia
          Local Time:
          1:28 AM
          I also levelled my jackstands on an uneven floor and made sure that the doors lined up good before welding the SFCs in.
          • Agree Agree x 1
          • 72bluNblu
            72bluNblu FABO Gold Member FABO Gold Member
            9,095
            3078
            Nov 28, 2008
            NorCal
            Local Time:
            1:28 AM
            More than likely the car was sagging before the connectors were installed and the door had been adjusted to fit the sagging body. Now it’s not sagging anymore, and the door needs a re-adjust.
            As for the shop putting a twist in the car, I’m personally of the opinion you’d actually have to try and do that. I install connectors with the car leveled or on its suspension (I’ve done 3 of my cars so far), but I’ve seen guys install them while their car was fully stripped, handing on a rotisserie supported only at the ends, with the car hanging sideways so they could weld in the connectors standing up. And they didn’t have issues with getting their doors aligned on reassembly.
            • Thanks! Thanks! x 1
