clifftt
Anyone know where I can find replacement seals for these door moldings for ‘64-66 Barracudas? I see them listed for ‘67 and up.
Thanks!! I’ll give them a call.Detroit Muscle Technologies has them:
Mopar A Body 63-66, B Body 68-70 Quarter Window Leading Edge Seals - FLOCKED
What did you use? I would guess get the channel clean using solvent or lacquer thinner, then apply weatherstrip adhesive.I’ve replaced those before- really did not have much success- anyone documented the proper way to keep them from falling off during install?
Reporting back: Received my order from Detroit Muscle, weatherstrips almost identical, close enough. Cleaned the channel with lacquer thinner, then a smear of Permatex Weatherstrip adhesive in the channel of the molding and on the mating surface of the weatherstrip, fit great. No problems!
