[WANTED] Down shift linkage for 75 dart with 225 6 cyl and 904 trans
75dartron
Active Member
Gig harbor, Wa
Looking for the downshift linkage for a 75 dart w/ 225 6cyl and 904 trans. The carb was stock with a 1Barrel it now has a 2 barrel, dont know if there is a difference or not, bought it this way.
Thanks for the reply, trying to figure out if the one barrel is the same leakage as the 2 barrel, not having much luck.
PM you number and I will send you a picture of the set up I have for sale, I bought it thinking I could use it on my car, turns out I couldn't and I ended up using a cable set up for the dual two barrels on my 225 w/ a 904
