Draining the radiator
Shop, Garage and Tools
  1. Mopar Vince
    Mopar Vince I'd rather push my Mopar than drive any Ford
    124
    299
    Dec 10, 2018
    Santa Cruz, ca
    Local Time:
    2:13 AM
    Ever try to drain the radiator from the t-handled petcock into a container only to have the stream go wonky?
    Heres what I came up with to get the antifreeze into the container instead of the shop floor.
    I cut an old Lucas oil bottle and hung it on the petcock.
    It ain't dumb if it works right?
    • Like Like x 12
    • Thanks! Thanks! x 2
    • Agree Agree x 1
    • Heywodja
      Heywodja The Heartbeat Stops Here FABO Gold Member
      920
      547
      Aug 16, 2014
      Texas
      Local Time:
      4:13 AM
      Nice.. You need to put this in the How to section
      • Agree Agree x 2
      • Thanks! Thanks! x 1
      • MarPar
        MarPar Young Troubadour FABO Gold Member
        1,596
        3139
        Aug 15, 2010
        Madigadistan
        Local Time:
        4:13 AM
        I dig the overflow bottle. :thumbsup:
        I use a Mobil1 oil container for mine.
        • Agree Agree x 1
        • Dartnut
          Dartnut Don't hate me because i'm beautiful
          11,752
          4814
          Apr 19, 2007
          Southern Alberta
          Local Time:
          3:13 AM
          I always use a piece of vacuum hose or something that fits the end of the petcock and drain it into a jug or pail.
          Always worked for me.......
          • Agree Agree x 1
          • RammerJammer75
            RammerJammer75 Well-Known Member
            1,360
            1719
            Aug 28, 2020
            Kingsport, TN
            Local Time:
            5:13 AM
            Yep, that's why I use one of these lol
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            51,498
            20462
            Oct 14, 2010
            Idaho
            Local Time:
            2:13 AM
            This REALLY REALLY pisses me off. That I didn't think of this about 45 years ago!!!
            • Agree Agree x 4
            • Like Like x 1
            • 4spdragtop
              4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
              32,445
              13556
              Aug 28, 2009
              Wasting time here
              Local Time:
              4:13 AM
              Great idea, this is the best I've come up with. Works!
              • Like Like x 5
              • Mopar Sam
                Mopar Sam Well Fed Member
                1,502
                2254
                Jul 18, 2008
                Indiana
                Local Time:
                5:13 AM
                Mopar Vince, great idea.
                Now, can someone tell me how to drain the newer radiators with those stupid plastic petcocks? I have NEVER had one of them work. I always get mad and pull the bottom hose off and dump everything at once.
              • RammerJammer75
                1,360
                1719
                Aug 28, 2020
                Kingsport, TN
                Local Time:
                5:13 AM
                I've always had to grab them with a set of pliers to get them off, then if you're lucky it might drain.
              • Mopar Sam
                1,502
                2254
                Jul 18, 2008
                Indiana
                Local Time:
                5:13 AM
                I have used pliers too, but never have been lucky enough for one to drain. 99 durango, 03 ram both the same.
              • RammerJammer75
                1,360
                1719
                Aug 28, 2020
                Kingsport, TN
                Local Time:
                5:13 AM
                I've had luck with mine, but I've worked on a few with that same issue.
              • Mopar Sam
                1,502
                2254
                Jul 18, 2008
                Indiana
                Local Time:
                5:13 AM
                I did make the shroud 2 piece the first time I changed the water pump on the durango. I was glad I did the next time I had to change it.
                • Like Like x 1
                • RammerJammer75
                  1,360
                  1719
                  Aug 28, 2020
                  Kingsport, TN
                  Local Time:
                  5:13 AM
                  They fixed that in '01 or so, my '02 had a two piece shroud.
                  • Like Like x 1
                  • Ben Drinkin
                    Ben Drinkin Hey bartender! FABO Gold Member
                    19,877
                    14810
                    Sep 15, 2013
                    West Texas
                    Local Time:
                    4:13 AM
                    90 degree spark plug boot fits the petcock perfectly. Shoots right into the bucket.
                    • Like Like x 1
                    • Scamp Rhonda
                      Scamp Rhonda Well-Known Member
                      782
                      740
                      Jan 18, 2017
                      Blaine MN
                      Local Time:
                      4:13 AM
                      Brilliant!
                      • Agree Agree x 1
                      • 67Dart273
                        51,498
                        20462
                        Oct 14, 2010
                        Idaho
                        Local Time:
                        2:13 AM
                        I remember reading about some of the Chev/ GM stuff built in the late 70-80's. Not only did they not put block drain plugs in some engines, they didn't put rad drain cocks in 'em, either. Only way to drain them was pull the lower hose or siphon out of the side tank, and then knock out a frost plug on each side. I vaguely remember you could buy special freeze plugs with a drain boss in them.
                      • Duggie
                        Duggie Well-Known Member
                        472
                        351
                        Apr 10, 2020
                        Tacoma WA
                        Local Time:
                        2:13 AM
