drive shaft length
moparraceman
mansfield ohio
i have a 1963 dart 340 with 904 and 83/4 rear what would be the drive shaft lenght from center of u joint to center u joint ? thanks
Are you looking to buy a used one or make a new one?
are you using small U joints or large?
either way the only correct answer is for you to measure your particular situation
You can be sure you are in the ball park with your measurements by downloading your cars service manual and looking at the propeller shaft section and /or downloading the parts book and doing the same. That is, if your car came with that combo as an option.
MyMopar - Mopar Forums & Information - MyMopar Tools/Reference
Maybe you get lucky and someone else has the same combo but maybe they used springs that moved the rear back an inch or two? I would hate to layout $150 on a driveshaft only to find its too short.
