Driveline vibration
How much is a lot of weight? Tires less than 10 years old? (Check date code)
Have your bubble balance efforts checked with a spin balance machine. They put the weight on the side it needs to go on versus just the top/outside for bubbles.
Yea if you shimed and it changed sounds like your pinion angle is wrong
Think its 15 degrees one each joint is optimal
Update from a while back. Added a 1/4” shim on the tail shaft. Not perfect but way better than it was.
1.5 down plus 3.5 down equals 5 degrees angle at the pinion. The angle increases on decel.
