[WANTED] Driveshaft '73 340+4speed w/ 8.25"
3467151 1973-76 3.25 49.90 904/833 8-1/4 225 318 340 360 Duster Dart Sport
Don't know if there will be a part number stamped on it but it is 3467151 and it shows to be 49.9".
Thanks
Do you need correct # or just correct fit.
My Engine Machine shop I use is in Vista.
I could deliver it next week for gas money.
That sounds great! Thanks. I'll PM you with my contact info.
Still on the hunt. GTX John’s driveshaft ended up being for an 8-3/4 rear.
Somebody must have upgraded to an 8-3/4 from 8-1/4 and still have the driveshaft laying around.
Getting pretty close to having to pull the trigger on a custom built unit.
I was told manual or auto driveshafts will be the same length just as long as it was from and 8.25”.
Thanks.
Awesome. I am sure there isn't any difference in 73 and 76.
I really appreciate your efforts.
Thanks.
904 auto only, & unless the 4spd You have is an early-A '66, You'll need the 727 slip yoke swapped onto it.
The car's 833 is number's matching to the car and so is the engine and rear 8.25.
Are you confirming that the 904 and 833 are the same length? This is what I have researched but it never hurts to get it confirmed.
Yes, and most A's all used the small u-joint, but confirm what You have and are receiving. Both shaft-wise & slip-yoke wise.
This drive shaft I got here is 51” ujoint to ujoint.
