NoCar340
The Original Partstitute
I'm looking for a couple of driveshafts. Neither is an HP application, so I'd rather not pop for new.
The first shaft is 48.96" long center-to-center per the parts catalog, or near enough to 49". The transmission is an A833OD with the smaller output spline if your 'shafts happen to have yokes attached.
The second shaft could be anything from 45.60" to 45.85", depending on which parts book entry one believes. I would need a 727/A833 large-spline output on this one, again assuming an attached yoke.
Yokes I've got, so if you've got the correct length without a yoke it's fine. 7260 joints are more likely and fine by me.
