Drum brake adjusters?
Brakes for your Classic Mopar
  1. Captainkirk
    Captainkirk Old School Mopar Warrior
    3,358
    1563
    Apr 24, 2006
    Northern IL
    Local Time:
    7:18 AM
    So. I ordered and received new hardware kits, brake cylinders and brake shoes to install on my 8.75 rear axle. I will also be changing all the brake lines as well. Would you guys recommend I replace the adjusters as well as long as the originals work? They aren't that expensive, but it's not like anyone besides me will see them.
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    60,353
    26494
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    7:18 AM
    If the old ones work, keep them they're better than the new ones... Just clean them up and anti-seize the threads....
    • Agree Agree x 5
    • Like Like x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      2,469
      3348
      Jan 13, 2020
      Wisconsin
      Local Time:
      7:18 AM
      As long as they spin freely, just clean 'em and use 'em (I always put a dab of anti-seize on the threads). Just make sure you keep them on the correct side. If you'd prefer new, like you say, they're cheap.
      edit: Treed again!
      • Like Like x 2
      • Thanks! Thanks! x 1
      • MoparMike1974
        MoparMike1974 FABO Gold Member FABO Gold Member
        3,479
        2796
        Jun 16, 2017
        Maryland
        Local Time:
        8:18 AM
        Yes, these are usually reusable. I clean them up and put anti-seize on the threads. On the other hand, new ones are cheap and seem to work just fine.
        • Like Like x 1
        • A Body 440 WHY NOT
          A Body 440 WHY NOT Well-Known Member
          361
          143
          Sep 28, 2019
          Jersey
          Local Time:
          5:18 AM
          Make sure the “teeth” on the wheel is good too
          • Agree Agree x 1
          • RedFish
            RedFish Well-Known Member
            25,019
            3717
            Sep 5, 2007
            Local Time:
            8:18 AM
            I put a dab of white lithium grease under the floating cap/end. Most adjusters have a thin thrust washer behind that cap. Make sure it hasn't been lost. They dont work well without it.
            I dont put anything on those threads. That would just cause lining dust to collect on them. More cleaning to do next time.
            • Agree Agree x 1
