Drum brake weights interfering with cragar ss wheels
Tires and Wheels (Mopar Hubcaps Too)
  1. crawsfire
    crawsfire Well-Known Member
    102
    97
    Nov 13, 2019
    WA state
    Local Time:
    7:59 PM
    Hard to believe these drums are so off that they require huge weights spot welded to the outer drum. My cragar ss wheels wont mount flush. Do you guys grind them down or remove them completely?
    thanks
  2. Darter6
    Darter6 Well-Known Member
    4,042
    1287
    Jan 16, 2008
    Nevada
    Local Time:
    7:59 PM
    Well, I have been removing them since 70's without any ill effects.
    • Like Like x 1
    • Dana67Dart
      Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
      3,561
      2115
      Jul 16, 2017
      Northern Colorado
      Local Time:
      8:59 PM
      If you remove them you could have the wheels and tires ballanced on the car.
    • Commando66
      Commando66 She's a beaut Clark!
      1,882
      375
      Dec 2, 2007
      Gig Harbor, WA
      Local Time:
      7:59 PM
      Knock them off with a chisel.
      • Agree Agree x 3
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        46,917
        31208
        Jan 18, 2006
        Iowa
        Local Time:
        9:59 PM
        I had to remove them in my 66 to mount these wheels. I didn't pay close attention when I first bolted them on. I didn't make it out of the parking lot before knowing something was wrong. Fronts only.
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        14,039
        3462
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        9:59 PM
        I have taken lots and not have a problem. Then 1 time I did, took along time to find the vibe. Kim
      • kursplat
        kursplat FABO Gold Member FABO Gold Member
        2,156
        1305
        Aug 24, 2010
        so cal
        Local Time:
        7:59 PM
        does any place still do that?
      • Dana67Dart
        3,561
        2115
        Jul 16, 2017
        Northern Colorado
        Local Time:
        8:59 PM
        I would expect high end / performance shops have the tools.
        I have never had it done. But removing 1/2 a pound of iron from the side of a balanced drum would result in a bouncy ride
      • Fishing68
        Fishing68 Well-Known Member
        83
        26
        Nov 29, 2019
        Seattle
        Local Time:
        7:59 PM
        Can someone explain specifically why weights were put on the drums?... I mean I figure it is for balancing but the weight would have to be mounted before the wheels so does that mean the weight is just to balance the brake drum itself?...
        I have a vibration over 45mph that I am trying to eliminate. Pulled the rear passenger wheel and looks like there is a weight attached to the brake drum.
        Tempted to pull the weight off but like to get some input from someone who knows more than me (that would include just about anyone -lol).
      • Dana67Dart
        3,561
        2115
        Jul 16, 2017
        Northern Colorado
        Local Time:
        8:59 PM
        You hit the nail on the head.
        What I can't understand is how they can cast a drum and it be so much out of Ballance that it requires 2 - 2" long 3/8" thick weights
        • Agree Agree x 1
        • toolmanmike
          46,917
          31208
          Jan 18, 2006
          Iowa
          Local Time:
          9:59 PM
          Exactly. I have a little vibration but I couldn't tell you if it's the tires and wheels I installed (they were balanced already but I didn't check them) or something else. Whatever it is, it's not bad enough to worry about.
        • Fishing68
          83
          26
          Nov 29, 2019
          Seattle
          Local Time:
          7:59 PM
          Thanks... well I will leave the weight on for now and focus on checking over the most simple items to review. Was under the car today checking the steering linkage and the drive shaft including u-joints and differential + transmission yokes. Noticed two things: 1) Idler arm is sloppy at the K frame mount - looks like the bushing has been squashed/worn out. 2) the output shaft at the transmission has some play.
          Thinking the vibration is primarily in the driveline as it is most prevalent at speeds 50+ and goes away if I put the transmission in neutral and continue revving. Vibe is only a tiny bit in steering wheel and primarily in seat of pants.
          So thinking there may be a bushing in the end of the transmission that is worn?
          ...Anyone know if that is what keeps the transmission output shaft/yoke from wobbling during rotation?
          (Maybe I should start a new thread- Sorry don't want to hijack this thread but may be useful for others trying to diagnose vibration issues)
        • pishta
          pishta I know I'm right....
          16,515
          6199
          Oct 13, 2004
          Tustin, CA
          Local Time:
          7:59 PM
          $4.83. part #066
          Trans Parts Online 727 727 Transmission Parts
        • Fishing68
          83
          26
          Nov 29, 2019
          Seattle
          Local Time:
          7:59 PM
          Thanks Pishta. Appreciate the link. Will do some checking on install procedure. Any tricks?... Thinking I should also change out the seal at the same time. looks like there are a couple to choose from.
        • Daves69
          Daves69 FABO Gold Member FABO Gold Member
          4,732
          2849
          Feb 20, 2011
          WestOfChi
          Local Time:
          9:59 PM
          I had just one of those on a front drum way back. A spot weld on either end holding it on. It practically fell off for me. Two rears recently purchased had none at all.
          I didn't check mine then, but it might be interesting to know how much runout your uncut outer drum displays. Maybe an off center condition is causing the imbalance. After that what's left? The casting density?
          • Agree Agree x 1
          • 69_340_GTS
            69_340_GTS Well-Known Member
            3,785
            1678
            Jul 11, 2014
            Torrington, CT
            Local Time:
            10:59 PM
            Because only the inside is machined. The sand cast outside is left as-cast. There is probably a lot of run-out between the ID and the OD. The factory made them as fast as possible. Probably faster/easier to add balance weights later than it would have been to machine them more carefully on the lathes.
            • Agree Agree x 2
            • 71DodgeDemon340
              71DodgeDemon340 Well-Known Member
              2,298
              577
              Apr 2, 2011
              Tennessee
              Local Time:
              10:59 PM
              Most of the aftermarket drums for newer cars and trucks have flat spots milled in the drum in a spot which i assume is to balance, you shouldnt have a issue removing the weights.
