A body fever
Member
I have a 70 dart drums all the way around. The front ones shake some if you stab the pedal . Ive noticed if you turn tire by hand it feel tight then loose . Tap them with a hammer and all is good . So are the drums bad .I dont feel any pulsing when applying brakes no noises either. Any suggestions. Later I will do wilwood front kit for drum spindle. Thanks
