Dumb bell solid lifters
Discussion in 'Small Block Mopar Engine' started by Retroboy, Sep 10, 2018.
  1. Retroboy
    Retroboy Well-Known Member
    137
    52
    Jul 1, 2014
    South Australia
    Local Time:
    7:14 AM
    hey
  2. Dana67Dart
    Dana67Dart Most undignified way to get to Colorado!
    1,502
    578
    Jul 16, 2017
    Northern Colorado
    Local Time:
    1:44 PM
    Now this is a cryptic post. :lol:
    • Agree Agree x 1
    • Retroboy
      137
      52
      Jul 1, 2014
      South Australia
      Local Time:
      7:14 AM
      Sorry. Wanting to convert a 360 to solids. Early Dumb bell style will uncover the oil gallerys I assume?
    • Dana67Dart
      1,502
      578
      Jul 16, 2017
      Northern Colorado
      Local Time:
      1:44 PM
      Did the solid lifter become shaped like a dumb bell????
      Are solid lifters lacking intelligence (certainly not as smart as hydraulic lifters that can figure out how much gap to take up) there by being dumb bells?
      Inquiring minds what to know!
    • SGBARRACUDA
      SGBARRACUDA ROY FABO Gold Member
      13,092
      2852
      Dec 7, 2006
      PLANT CITY FL.
      Local Time:
      3:44 PM
    • pishta
      pishta I know I'm right....
      13,541
      3301
      Oct 13, 2004
      Tustin, CA
      View My Photos
      Local Time:
      12:44 PM
      depends on the lift, or rather the "sink" of the lifter as all LA's lift is based on base circle. Stock 64 273 pictured... lifter.jpg lifter2.jpg
      • Like Like x 1
      • Retroboy
        137
        52
        Jul 1, 2014
        South Australia
        Local Time:
        7:14 AM
        Thanks Pishta. I've been pondering your drawing. The oil gallery is about .600" down the lifter boss so the gallery is exposed to the cut out any time the lifter isn't riding on the lobe and at that point some oil must slosh around the lifter body. I've looked at a standard factory cam which measures a base circle of 1.34, a Racer Brown ST21 with a base circle of 1.21 and a Lunati hyd Voo Doo at 1.19". I also measured a standard hyd lifter at 1.89 and a Rhoads lifter at 1.89".
        So we have a maximum difference of .060" lifter height between the generic hyd and 273 Dumbells - big deal. The maximum difference between the smallest base circle (the Voodoo) and the dumb bell lifter height is around .150" so really it should work. The next step is to buy the Comp Cams Magnum 20-248-4 solid cam and a dumb bell and physically have a look. If the lifter doesn't allow the oil gallery to be exposed and it sits a little deeper the the lifter boss that will also help with the push rod angle.
        Cheers
      • pishta
        13,541
        3301
        Oct 13, 2004
        Tustin, CA
        View My Photos
        Local Time:
        12:44 PM
        the aftermarket cams also spec a longer pushrod as every one I've seen sold for the mechanical valvetrain is longer than the stocker. Makes sense as they all have a lower base circle. I have heard the myth that the dumb-bell lifters will window the oil galley too on a high lift cam. Im thinking the 273/2 cam had a lobe lift of .405 (ex) so the lifter bore is going to be .499 above the base circle: (.270+.229 rust band)~ .405/1.5=.270 lift at cam. So theoretically the max lift (drop) of a dumb-bell lifter ON A 273/2 BASE CIRCLE is .290 or .435 valve lift which is shorter than every factory 4bbl cam ('cept the 273/4), all hydraulic.. Maybe no myth? I dont know the base circle of a 273/2 cam though, is it really 1.34? so we can do some more math.....LA cam bearing Id is about 1.956 (smallest one lobe has to go through, #4). so any lift you have is going to drop the base that much / 1.5 (rocker ratio). Lunati at a 1.19 base circle has a max lobe lift of .383 or a .574 lift.
      • pishta
        13,541
        3301
        Oct 13, 2004
        Tustin, CA
        View My Photos
        Local Time:
        12:44 PM
        somewhere I see a .551 (.780 lower band minus .229 rust area) as the max lobe lift (.826 at valve!!) a dumbell can do without exposing the oil band...? Im spinning.....Yeesh, this should be called Motor math...
      • RustyRatRod
        RustyRatRod Just another dumbass. FABO Gold Member
        47,464
        12482
        Jun 7, 2010
        Georgia
        View My Photos
        Local Time:
        3:44 PM
        Custom pushrods. Problem solved.
      • j par
        j par Well-hung Member
        10,562
        3741
        Jul 2, 2014
        Portland Oregon
        View My Photos
        Local Time:
        12:44 PM
        The opposite of a barrel lifter?
      • AJ/FormS
        AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
        14,861
        4026
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        View My Photos
        Local Time:
        2:44 PM
        Jus asking, but the 284/484 is a hydro right?; will the ramps on it survive with running solids on them?
        I did run the solids on a 1973 teener cam, no problem, but that is a different story.
      • Wyrmrider
        Wyrmrider Well-Known Member
        877
        277
        Sep 5, 2016
        los angeles
        Local Time:
        12:44 PM
        I would not run solids on a 284/484 hydro cam but the intensity is low enough you could get away with it
        but why
        It's not like running a class with a "stock" cam rule
      • Retroboy
        137
        52
        Jul 1, 2014
        South Australia
        Local Time:
        7:14 AM
        No it's a solid lifter camshaft
      • AJ/FormS
        14,861
        4026
        Jan 19, 2014
        View My Photos
        Local Time:
        2:44 PM
        Oh yeah post #7 I missed it,sorry
