famous bob
mopar misfit
I have a question for you automotive electricians. I have a ford relay on the pass. side firewall about where the heater motor was. I`m getting worried now that I`ve about got the fish finished, about not having a neutral starter switch. The reason I used the ford relay was, (1) the welding cable was given to me, and that's as far as it would reach, w/ the battery in the pass. side of the trunk. (2) simplicity for a non automotive electrician. I rewired the whole car w/ an EZ wiring kit, and there is a lot of stuff wired to the relay, w/ fuel inj., and an MSD ign. So, my question is this: can I insulate the ford relay and wire the neutral starter wire to the base of it and make it work ? I don`t want to start changing the wiring to go back to a Chrysler relay. thanks for all opinions. sorry about long post !-------bob
